Eibach pro-kit - which springs go front and rear?
Need some help, did some searching but the posts have had conflicting information.
Which springs go to the rear? Rob Robinette's site says the wider/taller springs go to the rear. I've read posts saying the same and posts saying the opposite. Can anyone on here confirm?
Thanks!
Thanks!
As I remember, there are part numbers printed on the spring... it seems to me that the fronts are wider around, and the backs are longer... but its been a while. With the #'s, you could just call eibach and confirm.
I had this problem before and if you think logically the heavier looking spring should go up front since thats where the weight goes when you brake....someone please correct me if i'm wrong..
