So, bad tps, or soemthin
Old Mar 16, 2004 | 07:52 PM
BigJim's Avatar
trainwreck
Well my car starts up real nice. Maybe 3 turns nad it revs up and idles nice. After about 30 seconds its idle fluctuates like 500 to 1000 rpm. If i tap the tps is gets better. But it seems like its loosing power. Also if i turn on my cd player when the bass hits my dummy lights will go nuts, my idle will drop like its shutting off and sometimes the amp and cd player will just stop playing altogether. Any ideas?
Old Mar 16, 2004 | 08:06 PM
Jon_Valjean's Avatar
Get some 10 gauge wire and run a new earth from the top of one of your housings to one of the bolts on the suspension tower.
Old Mar 16, 2004 | 10:08 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
Bad alternator. What else does it do when you place a high electrical load on it (turn on lights, turn on stereo, turn on A/C, etc.).
If your car dies from all of this, it could either be a bad alternator or voltage regulator, or the ACV. Take a quick look and report back. HTH,
Old Mar 17, 2004 | 04:24 PM
BigJim's Avatar
trainwreck
well now the lights stopped doing that. But now my idle surges back and forth about 1500 rpms, then will sit nice and idle, then back and forth 1500 rpms then idle for awhile any ideas?
Old Mar 17, 2004 | 11:02 PM
LongDuck's Avatar
What model do you have BigJim? If you're driving an SE, you're looking at surging, but if it's a 12a w/carb, I have no explanation for you on the idle variation.
Reply back or add a signature line and we may be able to provide more help.
Old Mar 18, 2004 | 01:04 AM
heb09's Avatar
sounds like bad ignition modules.
Donald Hampton
Sep 20, 2015 09:09 PM
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
