rim fitting
Old Mar 16, 2004 | 04:08 PM
nima_taba's Avatar
rim fitting
There are so many contradictory posts on this topic that I thought I'd just ask.
The rims I'm interested in only seem to come in +40mm offsets. I have the following options:
17x7
17x7.5
18x8.
I'm going to be running Tein coilovers. Which of these will fit? And what tire width would you recommend?
Thanks in advance,
Nima
Old Mar 16, 2004 | 05:18 PM
Rxmfn7's Avatar
Do a barrel roll!
the 17x7s would be the only one Id be comfortable using with a 40mm offset. If you go with the 7.5" width, they will be 7mm closer to the sping. Whether or not it will rub with those coil-overs, I cant say for sure, but I bet it will be damn close, expecially with any wider of a tire than a 225.
BLK 93
11
Sep 9, 2015 10:56 AM
