Overheated and rough as Guts.. URGENT HELP
Old Mar 15, 2004 | 08:05 AM
asmodeuss's Avatar
I am in need of some serious advice...
I recently overheated my car on a long trip because (as I found out) it has a hole in the radiator and all the water evaporated.
I only had it tuned a week or two before this, and it was running sweet as and now it hardly starts and is rough as, bumpy idle etc, and just sounds fairly ill.
I am a student and don't have much money so any cheap DIY advice would be a blessing. Don't let my 7 stay sick
Old Mar 15, 2004 | 08:23 AM
Steve Shulz's Avatar
Doesnt sound good, any time a rotary gets overheated it usually (99% of the time) is bad. You could do a comp test to verify but it sound like you warped the housings, probably getting coolant into the chamber. I hope your luck is different but it doesnt look good. I wish you the best.
Old Mar 15, 2004 | 08:25 AM
enigma32's Avatar
Did you let it overheat for long?
If so, you've likely fried your engine and that's the cause of your rough idle.
Old Mar 15, 2004 | 08:28 AM
vette_freak04's Avatar
If you decide you can't afford to fix the car and want to sell it contact me. eternal_rage69@yahoo.com Sorry about your car though.
Old Mar 15, 2004 | 08:43 AM
85rotarypower's Avatar
love the braaaap
Chances are you need a new or rebuilt engine. You can do a compression test and report your findings. That will tell a lot. Another thing would be burning coolant. If you have a white cloud of smoke coming out the tail pipe then you are buring coolant, which would definately happen if you warped the housings.
joel(PA)
Oct 4, 2015 06:07 PM
Turblown
Sep 30, 2015 05:58 PM
Devon Murray
Sep 25, 2015 09:41 AM
