Rx-7 alternator in Rx-2
Old Mar 15, 2004 | 07:52 AM
multirotor's Avatar
Rotary Power !
How can I use a 1979 Rx-7 alternator with integrated regulator on a 1971 Rx-2 (external regulator) ?
Thanks !
Old Mar 15, 2004 | 09:40 AM
gambone's Avatar
I'm useing a alt from a 929 in my RX4. Just get the wireing diagram from the doner car and go from there, think there should be 3 wires, main bat out put and a two wire plug in, one is for the key (off & on), the other I don't remember
Old Mar 15, 2004 | 09:57 AM
Siraniko's Avatar
RX for fun
Im using a MX-6 alternator in the RX-3. same wire to the battery and I only use one wire on the 2-wire pigtail--that is to energize the field terminal. (any wire that has voltage when the key is ON)
Old Mar 15, 2004 | 01:43 PM
Jeff20B's Avatar
Lapping = Fapping
The other wire in the T shaped connector goes to the GEN light.
I had an '82 alt on a '73 RX-2 engine. The housing is rotated, but it still fits fine.
Old Apr 6, 2004 | 03:45 PM
multirotor's Avatar
Rotary Power !
Ok, I managed to burn my wiring harness trying to get this to work. Damn !
Anyone have an Rx-2 parts car ?
I need the passenger side wiring running from under the dash, through the firewall to the engine and the front of the car.
I can probably recover mine but I 'd rather use a good one instead.
Thanks !
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
