whats wrong with my car? carb related
Old Mar 10, 2004 | 10:19 PM
Gilby Clarke's Avatar
did the carb kit on rx7 i just got
cleaned everything super good
car wont start alone, i have to tow it and pop the clutch
then car dies
first the idle screw was too loose tittened it all the way in and let it go 1 and a half turns back
tried adjusting it alot , i kept doing quarter turns on the screw but nothing
what could be wrong? why does it die out
all the lines are plugged in correctly
my cousin whoi was the owner of the car before even came and saw it, and everything seems well
anybowdy knows what may be wrong?
i know its hard asking for help like this, but its worth a shot
Old Mar 10, 2004 | 11:45 PM
K-Tune's Avatar
FD Daily
somebody translate please.
Old Mar 11, 2004 | 12:04 AM
Suparslinc's Avatar
It's Back!
First make sure you have fuel/compression/spark. Then unflood the engine by removing the plugs from their journals and cranking the engine several times. Make sure you have a hot battery.
If you don't have any experience rebuilding carbs, then I hate to say it, but you might have done something wrong. Do you have a Haynes manual?
Old Mar 13, 2004 | 02:16 PM
ive done that before
still no luck
timing is correct
i dunno whats wrong
might have someone come and chek it out
highspeedrider
Sep 8, 2015 07:55 PM
rx7brandon
Aug 16, 2015 10:55 AM
pzr2
Aug 15, 2015 08:29 PM
