what is going on????
Old Mar 9, 2004 | 08:30 PM
Fuel524's Avatar
Question what is going on????
ok guys i just wanted to start out buy saying this site is the ****. i work like 8-12 hours on aircraft and when i come home i cant wait to find **** out about my 7. i know its a lil sad but hey its true. anyways i have noticed when i have either been idling a lil bit or just finished doggin the 7 and i go and turn ofand remove the key the tach fiddles around in the 2500 range and it sounds like the over rev buzzer giong off . the motor is off the key is out everything is off but it buzzes and tach fluctuates (a few seconds of this like 1-5) then nothing.??????????????????? at first i though it could be diesling but the motor is not running, turning over nothing. is this a possible ignition problem? some help would be great. ohh yeah i just ordered the kyb struts 4, k&n, those 4 lil o-rings for oil/cooler tower and a drain pan gasket, and fuel, filter, im a lil stoked to see the small handling improvments.
Old Mar 9, 2004 | 09:11 PM
QuagmireMan's Avatar
Registered Offender
sounds like the gears in the tach might be sticking, mine did the samething during the winter, i took it apart cleaned it well, and had no problems since.
Old Mar 9, 2004 | 09:27 PM
Rx7carl's Avatar
Airflow is my life
or you have an electrical problem. I'm an A&P too! I work on airplanes all day, then the 7's when I get home. Oh and Im in Fl too, Orlando.
Old Mar 9, 2004 | 09:42 PM
Fuel524's Avatar
what kinda birds do you work on rx7carl?? i dont have my a&p yet i am in the navy but still i work on the ea6b prowler. anyways. i think ill try the tach cleaning thing first. also i am now in WA. a big differance i sure miss the warm weather. but it is nice here though anyways could you email me with some info on sterling carb upgrade.
Old Mar 9, 2004 | 09:47 PM
Rx7carl's Avatar
Airflow is my life
Well now we only have B717's. We used to have B737-200's and DC-9-30's, but they are gone. We will be getting B737-700's in a few months. A6's? Never been in the service, but them are some badass planes. Knew a few guys who flew them in Nam (before my time), when they were a state of the art attack plane, very rugged airframe. Oh and the website is above my sig if your interested in a carb. Contact me thru there.
Old Mar 10, 2004 | 07:20 PM
Fuel524's Avatar
the prob has gotten worse now no guages read. any help please
Old Mar 10, 2004 | 08:11 PM
Fuel524's Avatar
someone anyone please help i have the next 4 days off from work and i didnt plan on this happening, my car runs fine but no guages are indicating anything i have good voltage from battery and alt. also my fusses are all good. any kinda help please, maybe a common problem you have even heared about might help me in troubleshooting the prob. thanks
Old Mar 10, 2004 | 08:33 PM
Fuel524's Avatar
Old Mar 10, 2004 | 08:55 PM
white84GS's Avatar
Sounds like an electrical problem. I mean its after you turn the car off and the buzzer sounds, the buzzer is designed to go off at high RPMs that is unless of course it gets power to it and then VIOLA it sounds.....my opinion
Old Mar 10, 2004 | 09:01 PM
Fuel524's Avatar
yes i know it is an elec. prob but now i have no guages on and the car is on my fuses are fine. alt is good and battery checks out ok. any suggestions
Old Mar 10, 2004 | 09:11 PM
Rx7carl's Avatar
Airflow is my life
You sure the fuse for the gauges is good? When mine falls out (every couple of months) all the gauges go dead and the buzzer buzzes, but the car starts and runs fine.
Old Mar 10, 2004 | 09:14 PM
Fuel524's Avatar
what size fuse is it 10 amp. ??? have you found out why the fuse blows every couple months. anyways i am on my way to get some 10 amp fuses right now. ill post info later. man sure wish i had a garage.
Old Mar 10, 2004 | 09:33 PM
Fuel524's Avatar
well i feel dumb but it is fixed it was 2 fusses, now i need to figure out how to keep it from happening. maybe some ground wires might help i dont know elec. not my thing but the 7 is fine. thanks everyone who helped.
Old Mar 10, 2004 | 09:36 PM
Rx7carl's Avatar
Airflow is my life
Mine doesnt blow, it falls out LOL. I suspect the contacts are old and tired (like me).
