Lsd??
Old Mar 9, 2004 | 12:18 AM
dark mephisto's Avatar
Rotating once again!!
Lsd??
I have an 1981 seven with 4-wheel disc, how do I tell if it has lsd??
Old Mar 9, 2004 | 12:45 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
burnout, if one tire spins then your LSD is not working. Because if you have disc on the rear, you should have a LSD
Old Mar 9, 2004 | 12:50 AM
81Rex6port13b's Avatar
I Push My Car Real Fast!
you can do what 81street said, or you can do it the neighbor friendly way and jack up the rear. spin one side and if the other side spins the same way you have LSD.
BTW if you have 4 wheel disk you have LSD.
Josh83rx7
Oct 2, 2015 07:13 AM
Josh83rx7
Sep 24, 2015 11:47 AM
