rotary=2cycle? think about it
Old Mar 8, 2004 | 08:52 PM
FD3SR1's Avatar
Question rotary=2cycle? think about it
now hear me out before you start in on this idea a rotaty engine has oil and gas in the same place in the engine in order to lub it right just like a 2 cycle right. you know that your oil get deluted and thined after awhile with gas because of this. so say you used 2cycle motor oil in your gas it all goes to the same place and would help with the problem of oil consumption you could just use you oil in the pan for your turbos and then ther is little need for oil coolers becaus the oil is the same temp as the gas which would also help with temp so in theory this would solve some problems.
I would just like to know if any one has thought about this idea or better yet have tryed it? (it works in theroy)
Old Mar 8, 2004 | 08:57 PM
FD3SR1's Avatar
Old Mar 8, 2004 | 08:58 PM
XSTransAm's Avatar
Ee / Cpe
you worded that really badly, im not sure what your trying to say... but its called premixing and lots of people do it.
Old Mar 8, 2004 | 09:07 PM
xstacy7's Avatar
I love when things work
This is the concept Pettit goes about, however they go about it in terms of the engine and the stroking, not the oil it burns. Even though they do sell the Protek
Old Mar 8, 2004 | 09:23 PM
FD3SR1's Avatar
sorry didnt mean to word it bad so if lots of people do it hows the outcome? does it help any?
Old Mar 8, 2004 | 09:24 PM
xstacy7's Avatar
btw, you got 3 threads out there on this same topic....
Old Mar 8, 2004 | 09:34 PM
FD3SR1's Avatar
if people premix all the time what brand do people use and ratio of oil to gas are they using? and is it really 2cycle oil?
Old Mar 8, 2004 | 09:43 PM
FD3SR1's Avatar
any one who pre mixes please post how you set your car up what brand you use and the ratio of oil to gas you use and why you think its better to pre mix. thanks
Old Mar 8, 2004 | 09:56 PM
RxSeven1's Avatar
um you need to do a search for "premix". And no matter what you need oil.
Old Mar 9, 2004 | 12:30 AM
Bio-Weapon's Avatar
Wha?
You use any TC-W3 certified 2 stroke oil at a ratio of 100:1 per tank of gas.
Old Mar 9, 2004 | 12:53 AM
Icemastr's Avatar
All Motor
Most of the time they premix because their standalone ecu does not support the oil metering pump, at least I think thats the reason.
Old Mar 9, 2004 | 01:08 AM
scotty305's Avatar
~17 MPG
You are correct in thinking that the rotary acts similar to a 2-stroke engine, since it's producing power at each revolution of the output shaft (crankshaft in piston engines).
I think using only gasoline/oil premix to lube the entire motor would be bad, because gasoline doesn't lubricate as well compared to oil, right? You should still use regular motor oil for lubricating the engine, especially in a street driven car, running premix all the time would be more expensive, I think.
-s-
Old Mar 9, 2004 | 02:39 AM
clayne's Avatar
PV = nRT
You are born in 1986 and own an R1?
What stupid *** parents purchased that death warrant for you?
Old Mar 9, 2004 | 02:40 AM
clayne's Avatar
PV = nRT
You thought wrong.
Old Mar 9, 2004 | 07:28 AM
DaveW's Avatar
Racecar - Formula 2000
You can't do only premix for all lubrication. 2-cycle engines have needle rod, crank, etc. bearings since they don't use pressurized oil for lube. The rotary would have to be made like that (needle bearing rotor, turbo, etc. bearings) to do it.
Old Mar 9, 2004 | 07:34 AM
blueskaterboy's Avatar
Olympic Muff Diver
isnt there 17 textbooks on this topic in the forum already?
anyway... tcw3. but it lowers the octane and it is bad if you put too much so i just put a tiny bit in the gas just to be safe from both ends. still cant find someone that sells valvoline, all i can find is castrol and even then they dont have much of it.
Old Mar 9, 2004 | 07:50 AM
Bio-Weapon's Avatar
Wha?
https://www.rx7club.com/showthread.p...hreadid=146142
It doesnt lower the octane enough to really make a difference. Obviously you still need engine oil for your turbocharger, but using 2 stroke oil for internal engine lubrication is better than using your engine oil. Engine oil doesn't burn as clean as 2 stroke oil. All this information is covered in that thread.
Old Mar 9, 2004 | 10:24 AM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
A rotary is a 4 cycle motor to address the title of your thread.
Old Mar 9, 2004 | 04:38 PM
mks's Avatar
mks
How's that? In terms of combustions per revolution of the output shaft, it's more like a 2-stroke.
Old Mar 9, 2004 | 04:54 PM
NukeGenius's Avatar
Dim Sum owns you!
If you look at the actual cycles of intake, compression, power, and exhaust it does all four instead of having the intake and exhaust happening at the same time. That's sort of the idea.
Old Mar 9, 2004 | 05:13 PM
XSTransAm's Avatar
Ee / Cpe
oh ****... here it comes
Old Mar 9, 2004 | 05:24 PM
2a+RoN's Avatar
You are born in 1986 and own an R1? What stupid *** parents purchased that death warrant for you?
HEY! I was born in 86 too. My parent's are not stupid, I paid for most of the car, and I don't think an FD is a death warrant, at least to me
In any case, the advantages to premixing is that it burns cleaner meaning: A)spark can be more efficient resulting in slightly better gas mileage which can outweigh the cost of the premix and B)it doesn't leave as much carbon in the engine (ever open up a premixed engine compared to a stock omp?).
Old Mar 9, 2004 | 05:40 PM
FD3SR1's Avatar
as for the born in 86 comment I am paying for it all I took out a lone to buy this car and my parents only co signed they didnt pay a penny! As for all the other responses i appreciate keep them coming i would like to hear more veiws on premixing who likes it and who doesnt and why
Old Mar 9, 2004 | 05:47 PM
XSTransAm's Avatar
Ee / Cpe
https://www.rx7club.com/showthread.p...ghlight=premix
mods please close this thread
Old Mar 9, 2004 | 06:21 PM
rotorbrain's Avatar
fart on a friends head!!!
you dont HAVE to premix. . . just reroute.
paul
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
