3rd gen Intake...
Old Oct 25, 2001 | 12:46 PM
3rd gen Intake...
I believe I read an old post regarding using the 3rd gen upper intake and the throttle body ????
If anyone has some more info let me know!
Old Oct 26, 2001 | 11:38 AM
What no Help?
Old Oct 26, 2001 | 01:44 PM
HuggyBear's Avatar
try the gen 3 support forum. they may have more knoledge about this issue. wish i could help
Old Oct 26, 2001 | 01:50 PM
turbojeff's Avatar
Do it right, do it once
I've got both an FD and FC, I also have a couple of extra motors laying around for both. I can say without a doubt that the FD upper intake won't fit an FC lower intake manifold, the FD TB is also much bigger than an FC, won't fit either. The bolt pattern is smaller on the FC. I haven't taken a look to see if the FD lower will fit the FC lower though. Doing this swap would require a custom fuel rail set-up.
Jeff
87 TII 13.92 2620 lbs
93 R1 13.59 2800 lbs
Old Nov 19, 2001 | 03:56 PM
I believe soul assasin uses the FD intake on his 400+ HP 7....
I need more info on this mod....
Old Nov 19, 2001 | 03:59 PM
zyounker's Avatar
root
You use the FD upper intake & TB.. You have to port match the lower intake & round out the to middle holes un the uper intake.. Do a search this was disscussed about 2 weeks ago..
-Zach
Old Dec 3, 2001 | 09:03 PM
Is there an adapter plate for bolting FD upper to FC lower???
Old Dec 4, 2001 | 11:23 PM
fcturbo2's Avatar
I started that thread!. I dont think i will be doing that mod though. I heard you have to do alot of things to make it fit and the set-up alone cost alot. If you want the set you can get it from this dude in japan name Jessie. You will find him selling 3rd gen stuff at the www.thepartstrader.com he wants 375 for all 3 parts. good luck. You can look for my thread if you hate waiting for replies.
Old Dec 5, 2001 | 12:27 AM
soul assassin's Avatar
GTR eater
all you have to do is make a adapter plate for the manifold or bore out yuor stock FC lower intake to match and redrill the bolt holes, good for about 30 hp! and the 400+hp should read 500hp+
oh yeah i am not sure if the stock fc computer will run the FD tps i did not have this problem since i am running a aftermarket ems that is something you need ot check on
Old Dec 7, 2001 | 01:10 PM
Soul Assassin...
The EMS won't be a problem replacing that with the Wolf 4D, whenever the decide to release it...
Do you have any good pics of adapter plate???
Did you just "gasket match" the lower intake??
Old Dec 10, 2001 | 02:53 PM
I could use some pics of that adapter...
demetlaw
Oct 2, 2015 06:22 PM
