Timing,Please help
Old Mar 8, 2004 | 01:19 PM
brianw's Avatar
Question Timing,Please help
Did a search and while I'm sure the answer is in one of the threads I can't seem to find it. I tried to set the timing by the book. If I am looking from the front of the car I think the mark on the left is the leading and the mark on the right trailing. I put them both on the mark according to the book and I lose major power. If anyone can help and give a how to on this I would be very appricative. Thanks in advance.
Old Mar 8, 2004 | 04:16 PM
gsl-se addict's Avatar
Super Moderator
If looking from the front of the car, the leading is first (right) then trailing. The engine rotates clockwise as you look at it from the front. If the paint marks are still there, the yellow is leading and the red is trailing.
Kent
Old Mar 8, 2004 | 04:17 PM
Dcrasta's Avatar
usually the marks are two seperate colors, white for leading orange for trailing, but the leading mark comes around first so direction of rotation being clockwise the leading mark is on the right.
Old Mar 12, 2004 | 12:57 PM
monad's Avatar
When I set the timing for the leading should I connect the timing light to L1?
Should then connect the timing light to T1 for the trailing? And where is the adjustment for the trailing?
Old Mar 12, 2004 | 06:39 PM
mazdaverx713b's Avatar
Have RX-7, will restore
you are correct about the wires. the trailing adjustment is on the vaccume advance diaphram. it is adjusted by loosening the two screws and moving the diaphram. be careful when you adjust this. it is VERY touchy!
Old Mar 14, 2004 | 02:02 PM
monad's Avatar
You were right about the trailing timing adjust. As soon as I moved it a little the car went dead I have been trying for 2 days to get fire to the plugs. and i haven't figured out why I am not getting spark yet. no spark for hig tension wire from coil ether. Anyone have any advice?
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
20B Forum
Aug 19, 2015 01:47 PM
