Finally, boost is under control.
Old Mar 8, 2004 | 08:46 AM
pito13b's Avatar
The Fogger
Here is what I did and results if anyone has the same setup. My pills were built into the turbo hard lines. With full exhaust and intake, non-sequential I would see 15lbs. Drilled the **** out of the pill and with nothing in the line I see 9lbs, with no wastegate porting. Anyways, just wanted to share my happiness and I will see if I can get it back to 12lbs.
Old Mar 8, 2004 | 09:36 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
Cool, but why didn't you port you wastegate while you were in there?
Old Mar 8, 2004 | 10:00 AM
Toadman's Avatar
Nomad Mod
The pills are in the wastegate lines and can be removed. Porting the actual wastegate would require turbo removal.
Old Mar 8, 2004 | 10:13 AM
pito13b's Avatar
The Fogger
Yup, wastegate requires removal of the turbos. My pills were in the nipples, not the rubber lines. My nipple got drilled I think some 94's and 95's were like that.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
