Attention, thoughs running a R&B header
Old Mar 8, 2004 | 07:52 AM
During a diagnoses of a recent problem I've been having. I found the hose from my secondary anti-afterburn valve had a burned hole underneath the hose due to the header, although there's 3 inches space between the two. The hole could not be seen from the top or bottom. Some WD-40 accidentally ran down the hose while I was searching the Carb for vaccuum leaks. My suggestion is make a heatshield to shield the #2 Anti-afterburn valve. Hope this is helpful info to save someone needless time wondering why the engines running rough.
Old Mar 8, 2004 | 08:27 AM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
You can either make a shield or get one from Mazdatrix. They are readily available.
alphawolff
Nov 17, 2015 05:57 PM
meat_whistle
Aug 12, 2015 08:41 PM
