Silicone Or Fact. Gasket
Old Mar 8, 2004 | 12:22 AM
Fuel524's Avatar
Question Silicone Or Fact. Gasket
I AM FIXING MY MINOR OIL LEAKS THIS WEEKEND AND I WANT TO KNOW IF I SHOULD JUST USE SOME SILICONE GASKET SEALANT OR IF THE FACTORY GASKET IS RECOMENDED? ALSO HOW MANY WASHERS AND OIL O RINGS DO I NEED TO ORDER FOR MY OIL/WATER COOLER? IT IS LEAKING AS WELL. ANY HELP IS APPRECIATED.
Old Mar 8, 2004 | 08:46 AM
rhinor61's Avatar
Turn off your CAPS LOCK, in the internet world all CAPS means you are YELLING.
Use a gasket where every it call for a gasket in the parts book, silicone sealant does not handle temperature change very well and will leak, at least in my experience. I remember the old days when my dad use to make his own engine gaskets out of a old cereal boxes. It works.....
The oil cooler needs 4 o-rings, remember to give them a touch of engine oil before installing them.
John
Old Mar 8, 2004 | 10:28 AM
vipernicus42's Avatar
Rotoholic Moderookie
Methinks the earlier models only need 2 oil rings. Vic Brit says 2, but I know the 84-85s need four.
What year and model of car do you have? That info is really useful.
And keep it quiet, use your indoor voice
Jon
Old Mar 8, 2004 | 10:41 AM
mazdaverx713b's Avatar
Have RX-7, will restore
indoor voice!
Old Mar 8, 2004 | 06:24 PM
Keaponlaffen's Avatar
