My friends TII eats 1 qt. of oil in 500 miles
Old Oct 25, 2001 | 09:52 AM
drewstrbo2's Avatar
Exclamation My friends TII eats 1 qt. of oil in 500 miles
What could be wrong? No signs of oil leaks. He has DP, MP, CB, intake, walbro pump
late
Old Oct 25, 2001 | 10:38 AM
maxpesce's Avatar
Ex fd *****
Check inside the hose to the IC if its full of oil (drippy wet not just damp-damp is normal) Then it is leaking from the turbo impeller bearing - otherwise may be bad rotor oil seals - Mine currently dump 1qt/380mi into my newly rebuilt engine
if it is not the impeller leaking - & is smoking it may be the turbine bearing leaking into the exhaust - this usually produces large amounts of bluish smoke
Old Oct 25, 2001 | 11:30 AM
Icemark's Avatar
He could be driving with his foot really into it as well, but 1 qt in 500 miles is pretty close to the limit.
Old Oct 25, 2001 | 11:36 AM
Six Rotors's Avatar
If it's an 87-88 he could have a sticking control rod on the oil injection pump.
Old Oct 25, 2001 | 12:36 PM
snoopster76's Avatar
Twisted Girl Chaser
mine eats oil too
i noticed large amounts of smoke when i get above 5000rpms and let off on the gas or shift, hence letting off on the gas. it eats alot of oil if i'm above 5000 rpms, which of course is almost everytime i'm not in fifth gear.
is this a sign of the turbo bearing seal leaking, my turbo intake is dry as a bone and i've got great compression.
Old Oct 25, 2001 | 12:48 PM
gnat's-ass7's Avatar
Re: mine eats oil too
Oh, we know what your problem is...
Old Oct 25, 2001 | 12:52 PM
maxpesce's Avatar
Ex fd *****
Smoke on lifting throttle (High Vacuum) sounds like worn Rotor oil seals.
a leaky turbo will smoke all the time I think
Old Oct 25, 2001 | 01:16 PM
Twisted Girl Chaser
i can boost 10-12 psi below 5000 and it won't do it and after it warms up it won't do it until like 6000-7000 rpms.
guess it's time for a rebuild
Old Oct 25, 2001 | 04:17 PM
ZachSpazz's Avatar
I wish I had a posse...
It's not rebuild time yet...just don't abuse the engine and you may have plenty of life left in it.
Old Oct 25, 2001 | 05:51 PM
Cameljoe's Avatar
1 qt of oil every 500 miles sounds about right. 1 qt of oil every 380 miles sounds like an oil burner.
