carb for 84 gsl-se..HELP ME PLZ
Old Mar 4, 2004 | 03:31 PM
r0taryr0ck3t's Avatar
carb for 84 gsl..HELP ME PLZ
alright... i just recently purchase a 84 gsl
i am looking to slightly mod it
with this i mean headers,intake, and exhaust
i am getting custom headers from an expert on the engines for about $400 dollars(canadian) so i guess thats like 650 american? he said it is supposed to add around 15% hp....for exhaust im getting full 3' exhaust
with no cats cuz we dont need em here in manitoba canada and for intake im doin the custum set up where you get a cone filter and set it infront of your rade.. im goin to use a aem intake.
now for the main thing...my carb!!!! i do not know much about carbs and im not sure what i should upgrade too or what kind i shoudl get for that matter... all you guru's out there... your wisdom will be much appretiated
thx
Old Mar 4, 2004 | 03:33 PM
oh crap...sorry guys.. a few mistakes in this its a gsl not a gsl-se and also i spelt rad wrong, sorry
Old Mar 4, 2004 | 03:38 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
*disregard everything said here in relation to above post!*
As an SE fanatic, I can say that your EFI setup can be improved on, but not by moving to a carb!
I'll get flames for saying this, but there's a reason why every new car out there has EFI as it's fuel supply system and not a carbeurator. Carbs are difficult to tune for different elevations and weather conditions, are not as fuel efficient as EFI, and are generally more problematic than a solid EFI setup.
The SE's RE-EGI intake system uses a 'Dynamic Chamber' to utilize the intake air mass that's moving into the engine, to build additional intake pressure for the opening port - this has a natural 'supercharging' effect, since this excess pressure helps to pack air/fuel into the rotor path before the port closes. Also, the SE's have '6'-port induction, which was the Variable-Valve-Timing of it's day (and for the rotary). This opens 2 additional air ports under exhaust backpressure (high load, high rpm >3800) which gives the engine more breathing room and accounts for it's increases in BOTH low-rpm torque (134lb/ft, stock) and peak horsepower at 135hp, stock. All of this with about 17/20 for city/highway mileage.
When you start to look at total engine performance, one of the reasons the SE's get this performance edge is the increased displacement, but the rest is the ingenuity that the Mazda engineers built into the EFI system to keep it competitive with Porche, BMW, and others.
Is there any doubt that the 2nd Gen cars all have both '6'-port induction and EFI systems??? The SE was before it's time...
But, hey, I'm biased. Slap a Holley on there - you'll be back...
Old Mar 4, 2004 | 03:46 PM
hey sry for the title.. i messed up and i feel like an idiot its actually a gsl not a gsl-se
lmao dont worry i may be stupid enough to make a mistake on a jey board but i wouldnt switch a efi for a carb
scissorhands
Oct 8, 2015 01:17 PM
