Sponsored by: CARiD
Transmission stuck in reverse
Old Mar 3, 2004 | 03:27 PM
jeremy's Avatar
male stripper
upon going to a friend's this past weekend, my tranny become stuck in reverse after pulling into a lot to turn around. the ironic thing was that i never even shifted it into reverse to get it stuck there. i've gone through some older threads here and it seems some others have had this happen but as per normal of this board, no one comes back to explain what happened or how it was fixed. so my friend paul happened to get online and find this article that describes EXACTLY the symptoms my car had. so i figured i'd post it up just incase someone else gets into this. i'm going to try this quick repair tomorrow if i get the chance.
http://www.miata.net/garage/stuckreverse.html
Old Mar 3, 2004 | 06:18 PM
Project84's Avatar
Open up! Search Warrant!
This happened on your RX-7?
Old Mar 4, 2004 | 07:55 AM
jeremy's Avatar
male stripper
pretty sure. symptoms are exactly the same. i won't be able to try the procedure until sunday though. there also were a few older threads on here that described the same problem, but were never answered.
Old Mar 5, 2004 | 10:20 AM
jeremy's Avatar
male stripper
this was my problem and the repair worked.
Old Mar 5, 2004 | 02:14 PM
Jeff20B's Avatar
Lapping = Fapping
Getting stuck in 3rd is probably better because at least you can sorta go highway speeds if necessary.
Old Sep 7, 2006 | 11:14 PM
Rotorhead
I am going to try this repair on my car tomorrow, since it is stuck in reverse, but can shift into 1st and 2nd. Aamco wants to replace/repair both clutch and tranny. F-em.
manoflego
19
Sep 30, 2015 05:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
subeone
Sep 24, 2015 09:58 PM
