Power FC Installed Power FC and Idles very high
Old Mar 3, 2004 | 09:02 AM
4estRX7's Avatar
I just installed the Power FC and the car seems to run okay except it ides at 3000 RPM. I tried turning the idle screw and it was already backed off all the way? Any ideas? It almost acts like the choke is on but it never backs off...
Any ideas? Is anyone close to Omaha that knows anything about tuning FD's??
Matt
My mods are in my signature!!
Old Mar 3, 2004 | 10:27 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Was this after you allowed the PFC to learn the car for 15 minutes at idle?
Old Mar 3, 2004 | 10:33 AM
4estRX7's Avatar
I thought I did the install correctly, but maybe not?
Can I startover somehow and erase the PFC memory?
Thanks,
Matt
Old Mar 3, 2004 | 05:45 PM
twokrx7's Avatar
Need more sleep
Sounds like you are adjusting the wrong idle air screw. Are you adjusting the screw under the elbow or one of the tb linkage screws?
Old Mar 4, 2004 | 08:49 AM
4estRX7's Avatar
I was adjusting the one under the throttle linkage. It has a little nut on it that you must loosen before it will turn at all. I guess there is another screw under the black filter that should work better?
Please advise...
Thanks,
Matt
Old Mar 4, 2004 | 06:28 PM
twokrx7's Avatar
Need more sleep
The idle air screw is under the elbow. Stand at the driver fender and look at the motor, the adj screw head is facing you but you cannot see it. Reach under the elbow and you will find it at the base of the elbow.
Queppa
Nov 18, 2024 03:47 AM
sYnth.
Aug 17, 2015 07:28 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
