hear are my mods what other things will i need?
Old Oct 24, 2001 | 02:56 PM
COLBALT's Avatar
crw smic
hsk down pipe
and mid pipe
apexi n1 dual exhaust
greddy type s blow off valve
field fule computer
manual boost control
after market radiatior
apexi front bumper
knight soprts side skirts
and a vented hood
can any one think os any thing ?
i'm only going to run 14 lb of boost will
i be ok?
Old Oct 24, 2001 | 02:58 PM
COLBALT's Avatar
ohhh
don't forget the 18" racing hart m6's
Old Oct 24, 2001 | 07:05 PM
pp13bnos's Avatar
Pineapple Racer
Might want to start thinkin about a fuel pump. CJ
Old Oct 25, 2001 | 10:26 PM
rrrmechanic's Avatar
a medium intercooler will help alot the one were you don't have to relocate your battery works very well and is the best one for a non ported "7"
Old Oct 26, 2001 | 12:54 AM
Bacon's Avatar
IRS 4 Life
umm he has a cwr smic.... stock munt ic
id get a pfc..ive never heard of "field fule computer"
Old Oct 26, 2001 | 01:55 AM
dclin's Avatar
Perpetual Project
If the Field (?) fuel computer is a piggy back, then you will definitely need a Boost Fuel cut defencer. If you hit a certain boost pressure, teh stock ecu will cut your fuel. This item keeps this from happening. No Fuel = lean conditions.
What is fuel cut off at - 12 or 14psi? Anybody?
Hey, what do you know? I have a brand new Greddy 3rd gen specific Fuel Cut Defencer for sale!
I would go ahead and get the Power FC though. You really can't beat that price that's going on right now.
The only reason why I was doing this chop/paste ecu (piggy back, fuel cut defencer) solution thing was because I have an automatic, and it's tied into the stock ecu. Stand alone ecus do not support autos.
I have decided to do a manual swap though, so I just ordered a PFC.
Best of luck!
Old Oct 26, 2001 | 02:22 AM
maxcooper's Avatar
WWFSMD
Yeah, I would also seek a better fuel computer. The PowerFC is a very good choice (works great, very easy to install), as is the Haltech (works great, much harder to install, but more people can tune it).
The stock fuel cutoff is not at just a single psi, but involves boost, RPM, and the amount of time you have been over the limit. The short answer is that it is about 12 psi, but that doesn't quite capture the complexity of what is going on.
If the Field fuel computer just changes the MAP sensor signal, you will hit fuel cut at even lower pressures. I don't know anyone that has used this on an FD, and it is well known that most of the generic piggy-backs don't work well at all for this application and the stock ECU.
You'll need a fuel pump, too. A Denso pump like the Cosmo or Supra one will probably work fine, as would a cheaper Walbro pump.
-Max
Old Oct 26, 2001 | 02:48 AM
Suprascene.com's Avatar
Definetly go standalone save your cash from piggyback hell and go standalone. I have a 95' MKIV and we just heard about AEM releasing a ECU system for our cars but at the same time APEXi is releasing one finally about same time beginning next year. Being a supra owner we spend up to like $6k in piggybacks (bcc, bc, tt, vpc, gcc) and you could even go other ways but in the end it's money to cut up your car and rtun off all these small boxes... plus your car never runs right and idles like ****. With a standalone everything can be fine tuned to your need and there is no ceiling. GO STANDALONE!
Old Oct 26, 2001 | 03:12 AM
dclin's Avatar
Perpetual Project
-Max
Hey Max,
So how about a scenerio where you have larger injectors/fuel goodies and you are using the piggy back to turn down (assuming you make sure the fuel upgrades provide much more fuel then needed @ desired hp level) the fuel on the stock ecu? Do you think it would encounter the same problem?
This was what was brewing in the little head of mine as a solution to the auto/fuel upgrade. No longer something I need to consider, but would be good for auto owners to know - thanks!
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
msilvia
28
Apr 14, 2016 12:58 PM
immanuel__7
Megasquirt Forum
14
Sep 7, 2015 07:25 PM
