Is the spring itself considered "unsprung" or "sprung" weight?
Old Mar 2, 2004 | 12:00 AM
BicuspiD's Avatar
Infamous...Butcher...
How about the shock absorber?
Old Mar 2, 2004 | 01:36 AM
maxcooper's Avatar
WWFSMD
Double post... I'm a dingleberry.
maxcooper's Avatar
WWFSMD
Both are half and half (the exact proportion depends on the configuration). Part of the component moves with the suspension (unsprung) and part of it moves with the body (sprung).
-Max
Old Mar 2, 2004 | 02:22 PM
you are wrong. it is actually springing weight
Old Mar 2, 2004 | 02:26 PM
artowar's Avatar
FD3SW211E55
Are you saying that the spring, or the damper, or both are "springing" weight?
Old Mar 2, 2004 | 03:07 PM
DamonB's Avatar
Any component that moves as a wheel goes through bump or rebound is unsprung weight. So the springs and dampers are actually both sprung and unsprung weight. The portion of the damper tied to the suspension is unsprung weight because it moves with the wheel. On an FD that means the bodies of the shocks are unsprung and the piston rods in the shocks are sprung. Something like the drive axle on in independent suspension is also both: one end is fixed to the chassis via the diff and one end moves with the suspension.
Just think of the description of the words. "Unsprung" means everything the springs do not support. The weight the springs support is anything tied to the chassis. Anything that is "below" the springs (like the suspension) is unsprung weight.
Old Mar 2, 2004 | 03:33 PM
hehe
shocks dont spring. they are called shocking weight.
Old Mar 4, 2004 | 10:15 PM
OC_'s Avatar
OC_
I'm bastardizing my car!
i think half the shock and spring weight is unsprung weight.
Old Mar 5, 2004 | 12:42 AM
maxcooper's Avatar
WWFSMD
Quadruple post! Hmmm... I was a dingleberry for a double post, that makes you a quimby.
-Max
Old Mar 5, 2004 | 01:07 AM
88IntegraLS's Avatar
Displacement > Boost
WTF is springing weight? That is not an engineering term I have ever seen used before.
Old Mar 5, 2004 | 02:58 AM
artowar's Avatar
FD3SW211E55
Apparently "springing" weight and "shocking" weight are engineering terms that only exist in FCPowah's world...
Old Mar 5, 2004 | 03:05 AM
maxcooper's Avatar
WWFSMD
These jokes are starting to have a tiring weight on me.
-Max
bad jokes a-plenty
Old Mar 5, 2004 | 12:31 PM
hahahah awww Hell no!!
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Shainiac
Jul 17, 2019 02:20 PM
Ernstudet22
Sep 14, 2015 09:19 PM
