Bad "dizzy" or belts.. pleas help me! She wont run!
Old Mar 1, 2004 | 12:47 AM
Ok, the car wont start, when i jump her she runs fine until i stop, and then everything lit goes off or very dim. When i Rev it, it works fine. I know i have belts that need to be replaced, so this week i am putting her in the shop at my school (I WILL BE WORKING ON HER, no one else w/o me) but what do i need, and i need it asap, as of i will be driving my summer 1954 nash in the meantime which hates rain.
To me, i need a alternator or sumthin, and new belts. Im going to remove the rat's nest since shell be in the shop also. I need a printer friendly version though... and i dont have spare cash....
Old Mar 1, 2004 | 06:08 AM
Steve Shulz's Avatar
Yes, definately your alternator and new belts. Do more searches for the rats nest removal, youll find it.
Old Mar 1, 2004 | 10:15 AM
82transam's Avatar
Never Follow
Yep alternator should do it. Dizzy? what makes you think the distributor is bad?
Old Mar 1, 2004 | 10:22 AM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
Alternator- If the dizzy was bad, I doubt she'd run 'fine' when you roll start her.
Old Mar 1, 2004 | 11:04 AM
white84GS's Avatar
It Has to be the alternator, why else would the lights dim if it wasnt? The Dizzy wouldnt do that....you would have no get up and go if it was just the dizzy.
Old Mar 1, 2004 | 12:02 PM
GavinJuice's Avatar
Leave A Message
could be a bad ground, most likely it's your alternator. Have it rebuilt instead of buying a "remanufactured" one. Save yourself some $$$
Old Mar 1, 2004 | 03:30 PM
pratch's Avatar
Mazspeed.com
Send an email in lieu of donation, and if you are sincere, we'll hook you up. Of course, it could be argued that if you have the printer ink, you can afford the donation, but only I'm that big of a dick - Carl's a sweetheart
http://www.ten15.net/Maz.Tutorials/
Old Mar 1, 2004 | 09:18 PM
kettlman's Avatar
THE ONE. THE ONLY!
ok. lets get to the problem. first off, what have you done to try to shoot flames? could that have done something ? i know you were talking about another coil to a plug, retrace what you did at first. then, check and make sure your belts are tight. jump it , take it to auto zone, or shucks and have them check your alt. and battery. especially the battery. they will do it for free. cause you said you can jump it and it runs fine until you stop. but when you rev it it runs fine. so check the belts and the battery after you retrace your wild fling of shooting flames. good luck.
Old Mar 1, 2004 | 09:38 PM
Ha ha ha, no this problem exsisted. before the flames, i got a good deal on a new alt from action-auto (local store) for $100, im getting new belts as well.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
Wolf_
Aug 11, 2015 04:23 PM
