Wheel Conversion?
Old Oct 24, 2001 | 04:56 AM
Rob96GTI's Avatar
Newbie
Question Wheel Conversion?
Hi, I am currently trying to find a way to convert the wheel pattern on a '85 RX-7 GSL, I am working with the 4 lug pattern, I am trying to
use Front Wheel Drive 4x100 wheels, First, will I be able to fit the 17x7.5" Wheels at stock hieght, second, how do I go about changing the
bolt pattern or using adapters, and what size adapters will I need? I would like to know if there is another vehicle I can swap parts from to
do this swap inexpensively, or if I just need to go with adapters. The wheels I am hoping to use are coming of a '96 VW Golf if that helps
any.
Can anyone help me out? We would like to resolve this issue by the weekend if possible. Thanks guys.
Old Oct 24, 2001 | 10:57 AM
dbb280zx's Avatar
You need parts from an 85 gsl-se.
They are 5 bolt.
Front wheel drive cars usually have offset.
Rx-7's need 0 offset.
If you do get them on there they'll rub the frame.
Sorry.
Denni§.
Old Oct 24, 2001 | 12:32 PM
NOTA V6's Avatar
They are 5 bolt.
Umm... Nope!
They are a different bolt pattern, but still four bolts.
Old Oct 25, 2001 | 12:21 AM
smnc's Avatar
EliteHardcoreCannuckSquad
For the umpteenth time.
1979-1985
S, GS, LS, 1983 LE, and GSL models used a 4 x 110mm bolt patern
1984-1985
GSL-SE models used a x 4.5 inch (114.3mm) bolt patern.
As I recall, both have a 0 offset, but I'm not 100% sure about that.
17 x 7.5 inch rims should fit with no problems, IF you get the correct offset and tires.
I have no clue how you can fit a 4 x 100mm wheel on there, or even if the offset is compatible. If the rims have a negative offset, you're SOL. If they have a positive offset it may be possible to use spacers. Still I don't know how you'd change the bolt patern.
Sorry I can't help more,
-Spencer
Old Oct 29, 2001 | 11:58 PM
GT1's Avatar
GT1
Seeing that your in Washington state will make this easy. Im in Victoria BC, and in town we have two places that can get bolt adapters/.75inch spacers, i think one of the sources gets them from a company that makes adapters for Porsche supercup cars. And with the CDN $ being worth as much as toilet paper you should love the pricing. The spacer offset lets you fit civic / integra wheels no prob.
SHC AUTOGRAPHICS : 1-250-360-2209 ,I think they charge $390CDN for the set of 4
BIG-O TIRES : 1-250-384-7477 ,I think they charge $400
rx7jocke
72
Jun 17, 2016 03:48 AM
