n/a guys, in search of just a little bit more air flow
Old Oct 23, 2001 | 07:16 PM
pp13bnos's Avatar
Pineapple Racer
For the last couple weeks i've been thinking about porting the little black elbo, right before the TB. It also gave me an excuse to go out and by a die grinder. But anyways, you would'nt beleive how much material you can remove from in there. To be honest though, i advanced the timeing of the car at the same time. So i guess i'll never know just how much more power, if anything it gave me. But if it helps air flow, just a little bit more...then its worth it.
Would someone else port there's and tell me if they noticed anything? Later, CJ
Old Oct 23, 2001 | 07:21 PM
Mykl's Avatar
I've heard that porting the intake manifold will yield considerable gains.
Old Oct 24, 2001 | 07:38 PM
pp13bnos's Avatar
Pineapple Racer
I know this is like splitting hairs, but today i removed the clear plastic lense on the front nose cone. So i can get more cool air into the engine compartment. I also took my die grinder, and removed all of the excess threads on the screws that hold the butterflys onto the shaft in the throttle body. Still did'nt notice to much power difference.
I guess i'm just trying to find little things to remove in the intake system. Even in the end, if its worth 3-5hp i think it'll be worth it.
CJ
Old Oct 24, 2001 | 10:19 PM
mazdaspeed7's Avatar
mad scientist
I did that...I didnt feel any gain, but every little bit helps. Go check out the thread about porting the intake manifold. That should interest you now that you have a die grinder.
Heres another cheap hp thing...Like the elbow thing, the gains were pretty much unnoticable, but my car was a little smoother, and the low end felt a little morepowerful. Cut the crush washer off your spark plugs. It moves the spark closer to the chamber, and raises the compression a very little bit. This is a tried and true trick for small engines, and one of my friends suggested we try it on my car, since my spark plugs need replacing soon anyways.
Old Oct 24, 2001 | 11:15 PM
spinner26's Avatar
It is possible to have your spark plugs in too far and make contact with the rotor itself. I also recall pictures of a wankel that met a quick demise at the hands of cranked in sparkplugs.
If it works it works but by golly be careful!
Old Oct 25, 2001 | 12:47 PM
mad scientist
I have an engine taken apart in my garage, and I checked the clearances on the rotor housing before I tried it on mt car. There is plenty of room. The spark plug is still about 1 mm from the inner edge of the housing where it might start causing trouble.
Old Oct 25, 2001 | 06:50 PM
mad scientist
Bump
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
Brice_Brice
Aug 18, 2015 10:42 AM
Clacor
Aug 14, 2015 09:17 AM
Wolf_
Aug 11, 2015 04:23 PM
