carb idle and roughness
Old Feb 24, 2004 | 11:28 AM
Todd Staples's Avatar
"A Piece of Work"
I removed my rats nest according to pratche's tut. Started right up, but seems to idle a little rough. Do I need to adjust the A/F mixture and the idle and is it normal to have to readjust the timing? I don't want a race car, just a daily driver that gets average MPG. Doesn't seem like my secondary is opening up either. Any suggestions?
Thanks,
Todd
Old Feb 24, 2004 | 11:31 AM
Rx7carl's Avatar
Airflow is my life
Re check all the stuff you capped/blocked. Classic symptoms of a vacuum leak.
Old Feb 24, 2004 | 01:01 PM
slashdawg00110's Avatar
RTFFAQ
I hate to ask the obvious, but ... how was the idle before you removed the rats nest? Is the idle worse now than before?
Old Feb 24, 2004 | 01:51 PM
"A Piece of Work"
Yes it is a little rougher. I guess I can take some carb cleaner and start checking for leaks. So removing the rats nest won't call for an adjustment in timing?
Old Feb 24, 2004 | 02:14 PM
RTFFAQ
No timing adjustment required.
Old Feb 24, 2004 | 02:25 PM
"A Piece of Work"
OK, I will recheck everything. Thanks a bunch
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
