Bobbing Headlight
Old Feb 23, 2004 | 11:03 PM
93 RX-7's Avatar
Bobbing Headlight
All,
Searched the site but couldn't find my question....
On my 79 RX-7, the passenger side headlight quickly "bobs" up and down when I'm attempting to put up the lights. It doesn't matter if I used the column switch or the dash switch. If I get out and catch the light in the up position and give it a gentle upward push, it will stay up. Seems to do this more when the weather is warm, than when it is cold.
Any ideas?
Thanks,
Old Feb 23, 2004 | 11:16 PM
Tree25is's Avatar
wow! possibly striped teeth on the gear wheel. or the motor is just tired in the one spot.
Old Feb 24, 2004 | 02:30 AM
1984se's Avatar
Ryan
Mine did this to at times it would just go half way and then the "eyes" would look
To solve your problem.
1. Open your hood.
2. Activate your dash switch.
3. Then pull the 1st or 2nd fuseable link. Look on the side of the fuse block thingy. RETRACT HEAD LIGHT MOTOR...see it???
3a. Open and close the curcuit. Watch the moving parts..
4. See where the motor "spins" the "arm" thingy that rotates "piviots" on like a "ball socket"
I know its confusing, but when you do it you'll understand.
Thast most likely where your problem is. Unless you just need to tighten a couple 10mm and philips.
Good Luck
-Ryan
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
