Highest rwhp on stock twins/stock injectors?
Old Oct 23, 2001 | 08:43 AM
Question Highest rwhp on stock twins/stock injectors?
Does anyone know the highest rwhp made w/stock twins and injectors?
I just made 337@13# (see thread in 3rd gen section) and am just curious as to how much more potential my setup has w/more tuning. I plan on doing ignition and injectors in the near future, but am sticking w/my current setup for a few more months.
Thanks for the input guys...
Old Oct 24, 2001 | 11:38 AM
SPOautos's Avatar
Hey, where did my $$$ go?
I think with the complete stock fuel system you could prob stretch it to 370 or so with some good tuning but that would probably be at the edge. Without race gas you cant run more than about 14.5 psi of boost. I guess its also going to depend on your motor, is it ported and such???
If your running a stock motor it might be hard to hit 370 but I'm going to ball park it around there.
BTW - I wouldnt run my car all the time to the limits that would make 370 on stock fuel system. If you upgrade your pump I've heard of people getting closer to 400 but I doubt it would be reliable of safe.
360 is probably a safe figure.
Later,
Old Oct 24, 2001 | 11:41 AM
SPOautos's Avatar
In the previous post while typing it I couldnt read you sig so thats why some of it might not make sense with your mods, like the ported motor part, I didnt know you had a ported motor and I forgot about you fuel pump.
You could probably strach it to 380+ if you wanted to run on the ragged edge at the track.
Later,
STEPHEN
Old Oct 29, 2001 | 07:26 AM
G 's 3rd gen's Avatar
Re: Highest rwhp on stock twins/stock injectors?
That's a hell of a set-up so far Steve!!!!! Get out there and give us an update on a quarter mile time!!!!! Try some drag radials or something!!!!
Old Oct 29, 2001 | 04:54 PM
Re: Re: Highest rwhp on stock twins/stock injectors?
Thanks for the compliments, man....the name's Rich though
I've given up on drag racing for the time being b/c I broke my PPF in three places about a month back. I was actually getting better times w/less power b/c of traction issues.
All those mods listed in my sig have left no $$$ for radials, PPFs, or a Kaaz LSD, so it's just street/highway racing for now
Rich
Old Oct 30, 2001 | 08:07 PM
Jedon's Avatar
Slave2TheFD
eccentric shaft mod
What is a "eccentric shaft mod" ?
Thanx!
Old Oct 31, 2001 | 07:39 AM
Arrow Re: eccentric shaft mod
Thanx!
I'd never heard of it before Dave at KDR suggested I do it. He basically removes a small pill which allows the motor to receive full lubrication at startup, thus (supposedly) extending engine life. It was like an extra 16 bucks, so I figured what the hell . The only drawback is you have to let the rex idle for a solid 5 minutes in the morning; the car doesn't want to rev when cold.
If you want a technical, 100% correct explanation, email Dave at kdrotary@enter.net and ask him; he'l be happy to tell you about it.
Rich
Old Oct 31, 2001 | 10:37 AM
Jedon's Avatar
Slave2TheFD
Oh that must be the removal of the thermal wax pellet.
Thanx!
Old Nov 1, 2001 | 08:00 AM
Thanx!
Yup. That's what I meant to say
Rich
Old Nov 2, 2001 | 09:53 AM
BO0STEDRX7's Avatar
HP
356RWHP@14 PSI STOCK INJECTORS AND STOCK ENG AND TURBOS AND 93 OCTANE GAS,AFTER PUT THE 2 EXTRA INJECTORS AND MADE 362+@17PSI ALSO ON PUMP GAS ..
Old Nov 2, 2001 | 09:59 AM
Re: HP
What mods do you have?
Rich
Old Nov 2, 2001 | 02:59 PM
BO0STEDRX7's Avatar
Re: Re: HP
Rich
eng stock
turbos stock sequentials (no polish or ported)
cosmo fuel pump
stock fuel lines
aic
electronic boost controler
afc
2extra injectors
pulleys
rx7 fashion frontmount intercooler
custom air filter by crispeed
fuel regulator
custom exaust by miami muffler
downpipe
upgrade clutch
and 17 psi of boost
soon the car will have an radiator upgrade
Old Nov 7, 2001 | 08:18 AM
Re: Re: Re: HP
eng stock
cosmo fuel pump
stock fuel lines
aic
afc
2extra injectors
pulleys
fuel regulator
downpipe
upgrade clutch
and 17 psi of boost
That's a hell of a lot of power for stock turbos and motor. Is that hp value corrected? Not doubting you man, b/c I wasn't there for the dyno run and will refrain from making a long-distance judgement . Can you post your dyno chart? I'd be interested to see the torque curve.
Old Nov 7, 2001 | 11:59 AM
BO0STEDRX7's Avatar
ASK CRISPEED FOR THAT
HE WOULD ANSWER YOU EVERYTHING ABOUT THE CAR..
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
