tirerack k-1's have a 17mm offset
Old Feb 19, 2004 | 08:30 PM
frigidmonkey's Avatar
rotor withdrawal
I keep reading recommendations about these wheels, but tirerack says the offset is 17 mm, don't we need about 38??? Won't that pull the wheels REALLY far inside the fenders and maybe even hit the springs?
Old Feb 19, 2004 | 08:33 PM
Lotus00's Avatar
spacers maybe?
Old Feb 19, 2004 | 09:04 PM
ioTus's Avatar
'84 5-letter
nope. 12a offset is about 20. 17 sounds pretty close to 20.
Old Feb 19, 2004 | 09:05 PM
Eville140's Avatar
17mm sounds about right for a car without the SE suspension. Less positive off set means less backspacing.
I am running some spacer/adpaters that are 1.25" thick with 6.5" wide rims with +35mm offset and they fit pretty good.
So if I took off the spacers the 17m offset sounds about right.
Later
Randy
Old Feb 19, 2004 | 11:19 PM
rotor withdrawal
so 17mm offset would put the wheels about the same place in the wheel wells as yours? I hope so because you're looks AWESOME, that's exactly how I want the wheels to sit
doritoloco
Sep 17, 2015 03:51 PM
