stock gauges with microtech
Old Feb 19, 2004 | 11:27 AM
shiftnmadkwik's Avatar
SUPERnaturally Aspirated
i did a search and not much came up..
when removing the stock harness, to replace with the lt8, what needs to be retained to keep dash lighting, and the temp/oil/fuel/volt meters functioning properly... do these need the ecu or is the system standalone?
Old Feb 19, 2004 | 11:51 AM
j9fd3s's Avatar
Community Builder
the only thing you need to do is run 1 wire for the coolant temp guage, as its in the engine harness
Old Feb 19, 2004 | 11:54 AM
Josepi's Avatar
Despise Enmity
Simple, don't take out the the drivers side harness, and make provisions for wiring the stock drivers side harness to the boost and water temp sensors for the gauges.
Everything else works fine without even touching it. I'll say it one last time, DON'T TAKE OUT THE DRIVERS SIDE HARNESS, YOU'LL ENTER A WORLD OF PAIN.
Old Feb 19, 2004 | 11:55 AM
j9fd3s's Avatar
Community Builder
yeah i second that
Old Feb 19, 2004 | 12:54 PM
so its ok to scrap the ecu then?
how neat does your install look josepi with the harness still there?
Old Feb 19, 2004 | 12:59 PM
Josepi's Avatar
Despise Enmity
Buried underneath the trailing coil and all the other accessories, you can't see it...
Old Feb 19, 2004 | 01:20 PM
gotcha.. seems like keeping a whole harness for 2 wires is silly, but i understand what youre saying.
Old Feb 19, 2004 | 02:04 PM
Josepi's Avatar
Despise Enmity
No, **** no man, we got a little misunderstood.
The driver side harness stays in. The engine harness can be removed. With the engine harness out, you have to remove the sub-harnesses for the windshield wipers and cruise control from the engine harness. Since their are now no wires going from the old engine harness to the drivers side harness (at the ecu) you'd have to run a few wires with the new provided harness should you choose to use the factory gauges.
Old Feb 19, 2004 | 05:35 PM
Dan H's Avatar
Zoom Zoom Boom!
Wish you told the previous owner of my TII that. Ahh...what a mess he made down there with the Microtech install.
Old Feb 19, 2004 | 05:47 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
will the cruise control still work without the stock ECU?
