Tranny???
Old Oct 22, 2001 | 07:19 PM
Talking Tranny???
Does anybody know what you have to do in order to put a turbo tranny in a non-turbo rex.
What advantages does the turbo tranny have over the non-turbo tranny??
thanx
Old Oct 22, 2001 | 07:58 PM
Mike W's Avatar
i believe that you need the tranny, driveshaft, diff., half shafts, flywheel/clutch, starter and counterweight... with all that the advantages are just a lot stronger drivetrain and a little bit higher gearing
Old Oct 22, 2001 | 09:20 PM
Rx_treme's Avatar
well you can do it one of two ways.
flywheel
clutch/pp
tranny
starter
driveshaft
diff
halfshafts
flywheel
clutch/pp
tranny
starter
driveshaft from n/a automatic
the stock diff is pretty strong until you gets lots of power and lots of traction combined.
Jason
Old Oct 22, 2001 | 09:32 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
flywheel
clutch/pp
tranny
starter
driveshaft
diff
halfshafts
You forgot the clutch slave cylinder.
flywheel
clutch/pp
tranny
starter
Nope... it's 2" too short.
Jason
It would be ok if it's LSD. Otherwise it isn't worth the effort. You could either have a auto driveshaft lengthened 2", or you could have the flange on the TII driveshaft re-drilled to match the pattern on the NA driveshaft. Or, you could have a driveshaft made with a TII front yoke and an NA rear flange.
Brad
Jetlag
Sep 29, 2015 06:52 AM
