Anyone logging fuel pressure?
Old Feb 18, 2004 | 06:59 PM
radkins's Avatar
If so how did you go about it. I have a DEFI guage on the way and I think I should be able to do it with that and the datalogit cause it is an electric guage.
Old Feb 18, 2004 | 07:06 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
actually, I found an electric sensor that has 0-5 volts output, that is explosion proof, and is 1/8 npt connection, they are not cheap, but then again nothing is explosion proof ever is, its for gas compression duty and retails for about 210.Canadian, I may due that and just patch it into the spare a/d input on my haltech..max
Old Feb 19, 2004 | 12:24 AM
rotarypower101's Avatar
sdrawkcab
ouch max! 210 There is a guy on ebay “pyrojoseph” selling 0-5v 0-100 psi honneywell sensors 2 for $20 shipped. I got 4 of them
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6763
get these you will be very happy with them
Old Feb 19, 2004 | 03:29 AM
little rotor's Avatar
**** that's cheap. Thanks for the link.
Old Feb 19, 2004 | 06:18 AM
Maxthe7man's Avatar
Yeah, thats definetly cheaper.....They have also been discontinued, are the wrong voltage and plastic bodied, not something I want on my fuel system...I am gonna spend the extra coin on the all metal one...Max
Old Feb 23, 2004 | 04:51 PM
setzep's Avatar
Are you just talking about the plactic "T" under the transducer or the top part where the weatherpac connector goes Max? The thread on the transducers posted above is 1/4"npt.
I got 4 of them also Planing on loging all kinds of stuff with them. Fuel pressure, intake manifold pressure vs exhaust manifold pressure and whatever else I can think of.
Old Feb 23, 2004 | 07:55 PM
sdrawkcab
That’s kind of what I was wondering??
What sensor did you get max, do you have a pic and a link to yours?
I plan on putting one of the sensor in a block that is easily seen and accessible with the fuel temp sensor. I am going to log fuel, boost before/after IC, want to know what this spearco core really is performing like and oil pressure
Old Feb 24, 2004 | 07:32 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
rotarypower101....... thanks for the link. i had been looking for a pressure sensor to log my fuel pressure and this looks like it will work....
howard coleman
Old Feb 24, 2004 | 01:13 PM
sdrawkcab
How do you plan on mounting the sensor for logging the exhaust pressure
Do you plan on extending a long tube off of the exhaust manifold to act like a heat sink of sorts? Or perhaps a nipple to a silicone line, to nipple and mount it in a block, or barbed fitting to female ¼ npt?
it would be nice to have a full metal body sensor in that situation.
Please get back to me as I would really like to know how you plan on keeping the sensor from not only getting fouled up from carbon, but keeping it at a happy temp for the sensor.
Did it say anything on the PDF file about the sensors operating temperature range?
Old Feb 24, 2004 | 01:17 PM
sdrawkcab
howard coleman
Don’t thank me thank the guys over at the innovative WB forum. http://www.innovatemotorsports.com/forums/index.php
Its nice when a forum is so helpful and everybody is open to learning and sharing ideas, instead of on a big ego trip.
Old Feb 24, 2004 | 06:24 PM
setzep's Avatar
I have a -4 male fitting I'm going to weld to one of the main runners on my manifold. From that I'll have ~2' of tubing coiled up with the transducer at the end of it away from the turbo/manifold. I'm guessing it should work fine for the tests. I don't plan on permanently mounting the sensor.
Old Feb 24, 2004 | 07:43 PM
Maxthe7man's Avatar
http://www.ascovalve.com/product_data/sensorsweb.swf
There is the link for the one I have been looking at..Max
Old Feb 24, 2004 | 08:27 PM
sdrawkcab
Thanks setzup, intresting way to solve the problem.
Thanks for the link Max, those are the same sensors that the guys from an engineering forum that I peruse quite a bit recommended.
Old Feb 25, 2004 | 04:55 PM
setzep's Avatar
I just got mine today. I'm guessing they are used in air brake systems because of the quick release tubing T's that come screwed to them. I guess I'll find out how well they like gas and exhaust fumes I figured at $7.50 a sensor I don't have much to loose even if they do fail eventually.
Old Feb 28, 2004 | 10:23 AM
sdrawkcab
Hey Setzep, have you found any good sensors for logging temp? water/air/oil
Old Feb 28, 2004 | 10:55 AM
setzep's Avatar
Yeah, the ones that are hooked to my haltech I datalog that way. I don't datalog oil temp but I do have a oil temp gauge I look at.
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
