Cold air intake project.
Old Feb 18, 2004 | 11:45 AM
xmotocrossx04's Avatar
Aight todays there is nothing better to do project is turning my cone air filter into more of a cold air intake. So the reason for the post is I want any and all ideas about either putting the air filter down close to the road somwhere or how to get air to it what should I use to build a air duct has any one done it, any pictures you know that sorta stuff so anyways thanks for the help.
Old Feb 18, 2004 | 01:20 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
I built a three sided box out of aluminum sheet metal and sealed it off to the hood with 2X2 foam insulation. I have a fresh air headlight cover that feeds the box.. However, it doesn't work so well when the headlights are up, so, when i have the front end apart to mount the FMIC, I'm going to make some ductwork to feed it from under the front of the car.
Old Feb 18, 2004 | 01:27 PM
White_Seven's Avatar
FC 2 NV
I did my own CAI/TID and dropped the cone filter down below the front headlight. You can see it at my website (in my sig, then go to CAI/TID Project). Here's a couple shots of it....
Old Feb 18, 2004 | 02:09 PM
strikland's Avatar
I was thinking of ripping out my washer fluid reservoir and running the intake there, but there was too much tish in the way.
White_Seven- I've heard people say that having the AFM not level caused them problems. Yours works fine like that?
edit: oh, that's what you did. Cool to see that it worked out. I'm gonna have to rip that sucker out now
Old Feb 18, 2004 | 02:31 PM
Nick86's Avatar
Yup, still here
You can either bring the cold air to the filter - or take the filter to the cold air.
I brought the air to me!
https://www.rx7club.com/showthread.p...hreadid=181680
The whole write up is in there.
(you'll have to do some scrollin' for pics.)
Old Feb 18, 2004 | 03:44 PM
Aaron Cake's Avatar
Engine, Not Motor
Whatever you decide to to, please run a water bypass. While you will never hydrolock a rotary, sucking in a litre or two of water will stall the engine and foul plugs. And if your car is turbocharged, you do NOT want all that water hitting a compressor spinning at 100,000+ RPM.
Old Feb 18, 2004 | 03:57 PM
Amur_'s Avatar
Refined Valley Dude
http://www.fc3s.org/how_tos/engine/cold_air_box.html
https://www.rx7club.com/showthread.p...hreadid=162691
Wolf_
Aug 11, 2015 04:23 PM
