285/35/18
Old Feb 18, 2004 | 08:24 AM
Gorilla RE's Avatar
GorillaRaceEngineering.co
Question 285/35/18
is 285 on a 10" w rim to wide for an fd's stock rear fender?
does it look ok or does it stick out? i know
275's are fine but never really seen anything
wider than that with stock fenders.
THANKS
Old Feb 18, 2004 | 08:36 AM
raising arizona's Avatar
Send me your BMX parts
I had a friend with 285's and they just fit...but on a 10" wheel its fine
Old Feb 18, 2004 | 09:03 AM
Gorilla RE's Avatar
did it look funny?
Old Feb 18, 2004 | 09:14 AM
Broken09's Avatar
I am becoming...
I think you'll have some rubbing issues. I was told you either need to run 285/30/18's or 265/35/18. Max Cooper I believe is running 285's search for his name and you should find out some more info.
Old Feb 18, 2004 | 10:34 AM
ptrhahn's Avatar
With the right offset you shouldn't rub in the rear w/ a 10" wheel or a 285/35, though folks commonly use 275/35 or 285/30.
Old Feb 18, 2004 | 11:18 AM
SleepR1's Avatar
Pete, I want so badly to try 10.5 wides with 295/30-18s in back
Old Feb 18, 2004 | 11:54 AM
Gorilla RE's Avatar
you're going 2 need some flares for those.
Old Feb 18, 2004 | 12:36 PM
SleepR1's Avatar
Really? Even with 1.5 to 2 degrees negative camber?
Old Feb 18, 2004 | 12:45 PM
rynberg's Avatar
It's funny how you post a thread asking if 275 or 285s will fit in the rear (they will, it's a proven fitment) and then tell Manny that 295/30s require flares......it seems if you knew one answer, you would know the other.
FWIW, Kevin Wyum ran 315s on the rear with the stock bodywork. He had to modify the trailing arms to fit the width inboard.
Old Feb 18, 2004 | 01:07 PM
ptrhahn's Avatar
Manny,
I'm positive its doable with the right offset... problem will be finding wheels in that offset with out buying 18" Fikses or Forgelines.
With my 17x10" +44s, theres at least 3/8" room inboard even with the stock trailing arms.
I never saw any more from Herblenny about the 10.5" SSR comps...
Old Feb 18, 2004 | 02:49 PM
SleepR1's Avatar
Check out Phil's site. It's got nice pics of his SSR Comps in 10.5 wide with 275/35-18s in back
http://jmcustoms.com/html/features/mazda/RX7-93.html
The rear Comps came from a TX vendor who used 79.5 to 67.1 mm centering rings. The rear 10.5 wides are 43 mm offset as I recall from Phil's descriptions?
I'm thinking how nice 9.5 x 17, 42-mm offset front, and 10.5 x 18, 43-mm offset SSR Comps would be with 255/40-17 and 295/30-18 P-Zero tires fr/rr
Manny,
Old Feb 18, 2004 | 03:25 PM
ptrhahn's Avatar
I would think it'll look strange if your sidewalls are smaller in the rear than front. Functionally, it should be fine.
I was thinking of doing the same with 255/40/17 front, 275/35/18 rear.
Yes, I know that the rear is much taller, but the reality is, i've already lowered the rear much more than the front (the wheel wells and fender heights are very different in size), so worst case scenario is that i return the car to the factory proportions in terms of rake front to rear.
Old Feb 18, 2004 | 03:33 PM
SleepR1's Avatar
Yeah, someone's done this before, and you're right, the tire sidewall has to stay the same relative height as a ratio to the wheel diameter.
Old Feb 18, 2004 | 03:38 PM
ptrhahn's Avatar
Manny,
How many peoples perfectly innocent threads do you suppose you an I have hijacked to yack about fantasy wheel and tire setups:?
We have to be the worst window shoppers on the forum. :-)
Sorry internalconsucktionengine!!
Old Feb 18, 2004 | 03:57 PM
SleepR1's Avatar
LMFAO
Manny,
Old Feb 18, 2004 | 04:09 PM
xchaos's Avatar
This is the main reason I went with the 275/35s on the rear. I actually wanted the slight gearing change with the taller tire. How wide would a 10.5" wheel support? Can you go with 300+/30s back there on a wheel like that. Or would a +50 and 10.5x18 with a 300+ width tire just be too wide?
The 275s of the ES300 I got are very wide for this width. I'll be posting pics tonight in another thread and can show the 295 next to it (now unmounted).
Old Feb 18, 2004 | 04:13 PM
ptrhahn's Avatar
You won't find a 300-section tire. The generally go from 295 to 305 or 315.
For a 10.5" wheel, i'd max it at 295/30/18. I'd want an 11" for anthing bigger.
Old Feb 18, 2004 | 05:52 PM
xchaos's Avatar
I meant 300+, not exactly 300. I was thinking 305 or so to get the sidewalls close to the same in a stagger setup.
Old Feb 19, 2004 | 11:55 AM
SleepR1's Avatar
Old Feb 21, 2004 | 05:33 AM
bkapold@aol.com's Avatar
Not sure if you guys remember Kevin Tan but he had the 285 on the back as I posted previously. There were tight, but the CCW's obviously had the correct spacing...
Of course then theres Kevin Wyum who has 17 x 11 w/ 315 tire and up front he has 17 x 10 w/ 275 ( I think thats the wheel width up front) . Now thats impressive up close. He all shared Wyum's garage one Winter back in 97 so I got a good look at both of there wide wheel setups....I too got the wide wheel fever and run 17 x 9.5 w/ 275, but thats on a 91 Turbo ....
Old Feb 21, 2004 | 12:39 PM
ptrhahn's Avatar
It would be cool if Kevin Wyum (since he's back now) would share some details and pics on his 17x11" rear setup. There seems to be more interest in this extreme size than there used to be what with cars making 500 rwhpo and all. As I remember, he had to keep his car kind of jacked up to make it work. I know another person w/ 17x11" CCWs, but they are mounted w/ 275/40 hoosiers.
It might be easier to run an 18x11 now, what with all the 18" tire sizes that are available now.
Old Feb 21, 2004 | 02:43 PM
rynberg's Avatar
Here's a pic of the 17x11 with 315s that Kevin ran. The trailing arm is spaced over to make it fit....that's a wide tire!
Old Feb 21, 2004 | 04:43 PM
Kevin did end up running a 5mm spacer w/ longer studs if I remember right. He also had to, lets just say fix the outer fender lip to allow the tires not to rub... They do fit though... He also used the M2 trailing arms, of course. But, ya alot of tire on his car...
Kevin? ya out there?
Brad
yumidraco
Jul 1, 2014 08:19 PM
