'87 RX-7 (non turbo)
Old Feb 17, 2004 | 08:54 PM
Newbie
Unhappy '87 RX-7 (non turbo)
Oh great RX-7 Gurus!
I hope and pray that someone has had this problem in the past and it was a simple fix.
The car strats up fine, and after warming up, the car idles just fine. When I drive it, it starts to drop ~500 to 1000 RPM for no apparent reason. Then when I stop, it rev's up fine, but when holding it at a steady RPM, it drops RPM, then comes back up after a few seconds.
I have tried the choke cleaner trick, but the exaust system seems to work fine. The fuel pump has been replaces less tha a week ago. Is there something I am missing here?
Please let me know if you have any idea on how to solve this delima!
Old Feb 17, 2004 | 09:08 PM
WAYNE88N/A's Avatar
a water thermo sensor going on the fritz is just one of probably several things that could cause this...does it "buck" or is it a smooth drop of 500-1000 rpms?
Old Feb 17, 2004 | 09:14 PM
WAYNE88N/A's Avatar
yep, somethin's goin on with this triple post ****...
Old Feb 17, 2004 | 10:59 PM
Icemark's Avatar
Stop posting 3 times... Only press post once!
Old Feb 18, 2004 | 06:28 AM
Newbie
It definately "bucks" when the RPM comes back up after a second or two.
Old Feb 18, 2004 | 06:45 AM
lnbrown5981's Avatar
Just take the blue pill..
is it like a vroom, put-put, vroom?
if so, you might want to check out your fuel pump, or injectors for leaks. oh yeah, checking the tps is good to.
battery cables....check...
hth
lamar
sherff
Feb 24, 2019 12:09 PM
Snoopy FD
Aug 19, 2015 03:40 AM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
