God damn rust!Help headlight?
Old Feb 17, 2004 | 04:55 PM
3RotorRocket's Avatar
Angry God damn rust!Help headlight?
Went to go change a headlamp and the bottom screws are all fuggen rusted bigtime I can't even unscrew em.The head of the screw is rusted so it's totally flat.I took an ice pic and and made out the phillups line and I still can't un screw it.What should I do?
Old Feb 17, 2004 | 06:19 PM
WAYNE88N/A's Avatar
do you have an easy-out set? (kinda like a tap, but have a reverse-thread-type spiral) drill a small hole in the screw head, insert the easy-out, unscrew...works on aircraft all the time
Old Feb 17, 2004 | 06:42 PM
No I don't
Old Feb 17, 2004 | 06:45 PM
patman's Avatar
Resident Know-it-All
use a file or dremel tool to cut a straight line across it so u can take it out with a flat screwdriver. if you cant do this, drill it out very carefully.
pat
<<Ayrton>>
Interior / Exterior / Audio
Sep 5, 2015 09:38 PM
