FD touch-up paint
Old Feb 17, 2004 | 03:27 PM
wmrobert's Avatar
FD touch-up paint
I have a '93 FD (red) original paint and have a few small chips on the lower body behind the doors. In the past I have used factory touch-up paint and langka with excellent results (on other cars). The problem I'm having is that the factory touch-up paint I've gotten (from two different dealers) is very thin. I've shaken it and apparently it is just a thin consistency. It takes 3 or 4 coats to cover a shallow chip. Has anyone had this type of problem? Is there a better source fror some thicker touch-up paint?
Old Feb 21, 2004 | 02:17 AM
luizajeff's Avatar
Check this place out...
http://www.paintscratch.com/cgi-bin/makepaint2.cgi
Old Feb 23, 2004 | 02:07 AM
fd3s93's Avatar
if its the front bumper your trying to cover up..then i wouldnt waste my time on it if i was you ..youll just keep adding more in the long run..go to a good body shop that will special prep your front bumper and itll wont chip as easly. hope this helps. good luck i hate chips too.
Old Feb 29, 2004 | 10:18 PM
ikpfal's Avatar
try this place
http://www.mazdastuff.com/product.cfm?ProductID=761
