Car wont start
Old Feb 17, 2004 | 01:11 PM
JCurry's Avatar
Shpee
Car wont start
Ok yesterday I put my intake back on the engine of my 87 n/a because the pulsation damper was leaking and the injectors were bad I put everything back on and charged the battery and tried to start the car and it wont even turn over it has only done this once before when I had the intake off I was testing the damper so I turned it over a little and then tried it again and it wouldnt even turn over and it itsnt even clicking at all not even trying.If you could help me out I would appreciate it.And I know that the battery is hooked up correctly because all the lights are on.
Thanx Justin
Old Feb 17, 2004 | 01:31 PM
SureShot's Avatar
Seduced by the DARK SIDE
Maybe a weak connection in a primary cable.
Try to crank it, then check for a hot spot in the battery cables.
Does the voltage drop when you try to start?
Old Feb 17, 2004 | 05:20 PM
JCurry's Avatar
Shpee
No the voltage dosent drop and there isnt a hot spot in the cables, but after trying again the starter solinoid does click
Old Feb 17, 2004 | 06:33 PM
JCurry's Avatar
Shpee
Any info about maybe a blown fuse or stuck relay or something please help
Old Feb 17, 2004 | 06:36 PM
WAYNE88N/A's Avatar
why ya tryin to start it with a leaking PD?
Old Feb 17, 2004 | 07:20 PM
JCurry's Avatar
Shpee
To check to see if it was functioning properly
Please any help I need this car running
Old Feb 17, 2004 | 07:21 PM
JCurry's Avatar
Shpee
Kyo
Apr 13, 2019 09:24 AM
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
ashleymiche
Aug 14, 2015 12:59 PM
