rough idle hot start problem
Old Feb 16, 2004 | 11:02 PM
Red 86 rx-7's Avatar
wet drifting dream
I have a 86 fc n/a So far I have replaced all 4 injectors,alt,plugs,wires,trailing coil,o2 sensor.Grounded the boost sensor,main engine ground to firewall,secondary injector ground to firewall.,I also replace the transistor for the bac valve in my ecu.My problem is this the car will not start when hot.If I let the car sit for and hour it will start but I have to pump the gas peadle to keep it going? The car also will not idle to well for too long.If I let the car sit and idle it starts to sputter and after like 5 min it dies.I have the variable resistor set to full rich the car will not run at any other setting.The car will start after it has cooled to a certain temp.could my problem be a temp sensor? What abought the thermo wax could it become stuck? maybe a stuck FPR? I am at a loss for the cure
Old Feb 17, 2004 | 12:28 AM
13bpower's Avatar
s4 for life
First thing I would do it check compression. That will narrow things down greatly.
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
