Sponsored by: CARiD
M2 Carbon CAI Box fitment problems. Need assistance.
Old Feb 16, 2004 | 04:25 PM
Pipsisewa's Avatar
Question M2 Carbon CAI Box fitment problems. Need assistance.
I just installed my M2 carbon fiber cold air intake box this weekend and it sits about a quarter inch too high. I can still close the hood, but it sticks up by the same amount. I tried to get it to sit lower but there is a coolant hose that is proped up on a bracket that prevents this. I know that I could get the box to sit lower if I cut this bracket (removed it), but don't know if that would negatively affect the hose/cooling system.
Any advice on the matter would be greatly appreciated.
Old Feb 16, 2004 | 05:04 PM
scratchjunkie's Avatar
sexy no jutsu
what radiator do you have?
Old Feb 16, 2004 | 05:19 PM
Pipsisewa's Avatar
stock
Old Feb 16, 2004 | 05:37 PM
AREITU's Avatar
cool story bro
Do they even sell aluminum ones anymore?
Old Feb 16, 2004 | 05:53 PM
Pipsisewa's Avatar
I don't think so. Try Rx7 fashion (i think) or do a search for aluminum cold air intake box's.
Old Feb 16, 2004 | 05:54 PM
Pipsisewa's Avatar
I found a good site about this very issue:
http://www.scuderiaciriani.com/rx7/intake_install.html
Old Feb 16, 2004 | 06:56 PM
Kento's Avatar
2/4 wheel cornering fiend
The M2 airbox should rest on top of the frame member on that side without undue clearance problems with the upper radiator hose. Once I managed to properly line up the primary turbo intake hose (MAJOR PITA), the rest of the install was a cinch. You can flip (reverse) the top radiator mount brackets for additional clearance if need be.
Old Feb 16, 2004 | 06:59 PM
GsrSol's Avatar
Z06 powered FD
I had the same problem and I just removed that bracket and pushed the hose down.
Old Feb 17, 2004 | 07:47 AM
Pipsisewa's Avatar
yeah, I'm just going to remove the bracket. I think that is what M2 did as well. Wish they would have made some instructions. The install is fairly straight fwd but minor "glitches" can cause confusion.
Old Feb 22, 2004 | 08:42 AM
7racer's Avatar
The rx7fashion box fitment isn't that much better either...
it hits the radiator hose and doesn't seal off the radiator as there is a small "gap".
The only real benefit that I had heard is that it does sit lower and thus no issues with hitting the hood.
BTW, where did you get your airbox from??
Is it a new one from M2?
Old Feb 22, 2004 | 09:07 AM
Radical Rotary Avantgard's Avatar
Sleeper
Cool
I had the original aluminum CAI from M2 (4 years ago)and had NO fitments issues.
I went single, sold it and now I have the all aluminum CAI from RX7 Extreme modified for a single.
I had a little issue with hitting the radiator hose. I got fixed once I installed the wide foot mounts, that lowered the radiator a tad and the good old hammer.
I knew the CAI would see my way.
Old Feb 23, 2004 | 08:15 AM
Pipsisewa's Avatar
I got the airbox off of this forum, and yes it is the new one from M2.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
The1Sun
Sep 7, 2015 10:21 PM
