Sponsored by: CARiD
bad ignition timing -> low mpg
Old Feb 16, 2004 | 01:56 AM
w_hari's Avatar
Question bad ignition timing -> low mpg
Hi Folks,
during the last year my mpg constantly drops. Lately I replaced the fuel filter without any result. Can a slightly wrong ignition timing lead to higher fuel consumption? Or what else do you suggest.
Harry
Old Feb 16, 2004 | 10:27 PM
black_sunshine's Avatar
Worse-case scenario for bad engine timing is lack of power or detonation. Maybe your driving style has constantly changed within the last year? At any rate, your engine's timing has a small effect on economy; the difference between running retarded (timing) and running way to advanced is usually no more than .5-3mpg. Keep in mind that temperatures effect fuel ratio quite a bit, as does load and drag.
Old Feb 17, 2004 | 12:31 AM
rotarygod's Avatar
Rotors still spinning
A 3 mpg change when you only get 18 or so to begin with is pretty significant.
Yes timing can effect gas mileage. There are many things that can. Just start checking/adjusting everything until you narrow it down.
Old Feb 17, 2004 | 02:18 AM
w_hari's Avatar
Thats right! I used to have about 25 mpg and now its about 21, without changing my driving style and still drive the same road to work every day.
I thought it might be timing because it sometimes backfires after high rpm and suddenly decellerating. My car never did this the years before.
Thanks anyway!
Harry
Old Feb 17, 2004 | 11:07 AM
rxsevn89's Avatar
look at your spark plugs. may be wearing out.
Old Feb 20, 2004 | 08:20 AM
w_hari's Avatar
UPDATE
Visited my mechanic today:
Ignition timing is pretty good.
But the car seems to run too rich because the Co2-Values are to high (should be 0.1% but is 0.7% btw. europe-model without cat) but they didnt want to change the mixture :-(
I know the idle mixture screw is near the air-box. But there seems just to be a round screw in there that you cant turn!? Any help would be apreciated.
Harry
alphawolff
Nov 17, 2015 05:57 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
