idle sticking until i pull up gas pedal?
Old Feb 15, 2004 | 08:01 PM
rotarypower83's Avatar
what is th remedy
Old Feb 15, 2004 | 08:02 PM
KehoeAutomotive's Avatar
Fuel Injected or Carb?
Check your return spring.
Old Feb 15, 2004 | 08:09 PM
carb
all of a sudden i have to pull gas pedal up to make it drop from 1500 to 800
where is spring?
Old Feb 15, 2004 | 09:01 PM
mazdaverx713b's Avatar
Have RX-7, will restore
check the dash pot.
Old Feb 15, 2004 | 11:28 PM
Metallic_rock's Avatar
Ride 'n Style
could need some lube on your linkage, maybe the throttle cable, too... definitely check the return spring, though.. sounds like it might not be taking it all the way back down.
is it really easy to push down your gas pedal? if so, you may need to completely replace the spring.
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
R7rexy
19
Sep 2, 2015 10:24 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
