Tore down the junkyard holley, look Carl!
Old Feb 13, 2004 | 01:47 AM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
pic is not so great here is the exploded view
this is a 465 I think, holley number 1848-1.
Barely got the butterflies out, both shafts are seized, I think they will have to be cut out.
Most of the aluminum is ok, But almost another entire carb will be needed to rebuild.
see next pic of bowls also.
Old Feb 13, 2004 | 01:56 AM
Here is a pic showing the difference in bowls, the bowl with the white float is the accel pump bowl
Is this for all holley's, or rb's mod?
The side w/o the accel pump had no jets, some sort of block off plate, and a metal gasket, Is this rb's mod as well?
The side with the accel pump had #49 jets
As you can tell I know nothing about carbs.
Someone make me an offer if they want this thing.
Old Feb 13, 2004 | 09:26 AM
Rx7carl's Avatar
Airflow is my life
Wow, was that under water for 10 years? Not sure about the floats. The secondaries on a 4160 carb dont use regular jets. the plate you refer to is a metering plate which has fixed jets/holes drilled instead of jets. Thats standard Holley.
Old Feb 13, 2004 | 05:42 PM
Re: Tore down the junkyard holley, look Carl!
Will you take belly button lint for it? I'm broke.
Old Feb 13, 2004 | 05:47 PM
sorry, sold. you going to rotary revo rutnick?
I can't remeber If I asked you or not.
If so follow me and rotofire up there.
Coochas
44
Nov 5, 2019 11:08 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
