se fuel cut?
Old Feb 12, 2004 | 02:50 PM
matthewpims's Avatar
se fuel cut?
I did a search and didnt find quite what I was looking for. Does an 84 se have a fuel cut? Ive heard its at like 8000 but ive spun it higher than that doin a burnout, so is there one and its not working or isnt there one?
Old Feb 12, 2004 | 03:27 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
As far as I know, there isn't one. The only 'fuel-cut' controller is in the AFM so that the fuel pump isn't running unless you're cranking it, or it's the engine is running.
I've never had RPM limited due to fuel cut. HTH,
Old Feb 12, 2004 | 07:54 PM
I have been up to 8500 and it hasn't hit fuel cut. I have never heard of a stock fuel cut in a seven.
Old Feb 12, 2004 | 09:20 PM
85rotarypower's Avatar
love the braaaap
No fuel cut. I don't think the FC's even had a fuel cut. Not too sure about the FD's though.
Old Feb 13, 2004 | 10:24 AM
XLR8's Avatar
No the SE does not have a fuel cut. Which I never understood why Mazda would want the fuel to be cut in ANY case causing a lean mixture. If any rev limitation is used it should be done via ignition. I guess Mazda wanted all those TII guys to buy their remans.............that will teach them to mod their car
alphawolff
Nov 17, 2015 05:57 PM
Snook
21
Sep 1, 2015 06:32 PM
armans
Aug 15, 2015 09:08 PM
