Exhaust system
Old Feb 11, 2004 | 08:50 AM
Todd Staples's Avatar
"A Piece of Work"
Exhaust system
Have an 85' GS with a 12a. Exhaust is trash. Was going to replace the pre-cats with a down pipe then a good universal main cat with a good replacement muffler, both stainless steel. Do I really need to worry about hooking the air tube back up temp snesor and will it help to get rid of the air pump. Just want to keep enough to not get me into trouble with inspections in Missouri. Does anyone have a driver's side window regulator for sale along with a gray console with ashtray and shifter wrap?
Thanks,
Todd
Old Feb 11, 2004 | 09:05 AM
RXTbone's Avatar
Todd - welcome to the forum!
Try doing a search for your exhaust questions - there will be a TON of info on the topic. Generally, everyone will tell you to buy Racing Beat exhaust components, as they are specifically designed for the hot exhaust of a rotary...
On your parts, search the For Sale section.
The search function is your best friend. The forum has a wealth of information tucked away in its many threads...
Good luck!
Old Feb 11, 2004 | 11:21 AM
"A Piece of Work"
Thanks for the info. I will give it a shot. How exstensive a job is it to convert from a carb to FI on a 12a?
82streetracer
Aug 23, 2015 09:28 AM
GrossPolluter
Aug 22, 2015 11:23 PM
