60-1 Vs 62-1
Old Feb 2, 2004 | 08:29 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
60-1 Vs 62-1
Im still waiting to upgrade my To4b,
I was going to go with a 60-1 (actually, I was going to use a borg warner s200, which is a cheaper copy)
Someone suggested that I get the 62-1 instead.
What are the differences.
Im running a 1.15 Ptrim divided, off a tubular manifold, on a stock s5 block with a Haltech. I want to run about 10-12 psi on the street, and maybe 20 tops on the track with race gas.
60-1 or 62-1 what would you use and why.
Old Feb 3, 2004 | 01:40 PM
Beast From The East's Avatar
Racing is Life.....
62-1 will get you a bit more in mid and top
Had this conversation with Cliff at Turbo Power. Was considering upgrading the 60-1 wheel that came standard with the 62-1. He said I'd get a bit more in the mid and top range with the 62-1. For the street I'd notice little difference.
If you've got the turbo apart or plan on running that 20 lbs a lot, then go 62-1. If the turbo is already put together then ask yourself if you really need the extra. It sounds like you've already got it apart (or plan on taking it apart), so get the 62-1. I'm going to get it if/when this one needs a rebuild, but wasn't ready to shell out another $400 right now.
Beast
Old Feb 3, 2004 | 05:08 PM
I only have the housings off, the turbo is still in one peice.
The stock .60 A/r compressor looks really small.
I doubt that I will be running 20 psi very often. as I dont race the car that much. Plus, this is in a First gen model "S" the LIGHTEST rx7 you can get.
My goal was to get close 400whp at 20psi (mainly for bragging rights) I would rather have more bottom end then more mid and high. Because the car is so light, I thing a wider powerband would be faster than a mid to high powerband.
If I can get a generic 62-1 I might go that path, but the Borg Warner S200 is only a $200 upgrade, vs a $400 60-1 or 62-1 upgrade from turbonetics ect.
Old Feb 3, 2004 | 06:06 PM
$150FC's Avatar
Currently Winning
if you wanted bottom end, why did you go with the 1.15 a/r hotside?
Old Feb 3, 2004 | 09:11 PM
because it was cheap and divided like I wanted.
You can run a pretty large AR with a Ptrim, and Im looking for really "safe" HP on this engine and this should give lower backpressure and less general heat.
A 1.15 Ptrim with a .70 60-1 compressor is also the recommendation for a stockport 13b on Hitmans website. And he knows his ****.
Old Feb 3, 2004 | 10:52 PM
$150FC's Avatar
Currently Winning
hm. interesting.
Old Feb 4, 2004 | 01:16 PM
it also lets me run a smaller, cheaper wastegate, like a tial 38 or racegate, instead of something rediculously expensive, like a HKS GT
Old Feb 4, 2004 | 03:11 PM
$150FC's Avatar
Currently Winning
well, i just think if you are wanting low-end and thinking you're going to get it with a 1.15, you're mistaken. but, i don't know everything. we'll see
Old Feb 5, 2004 | 12:24 AM
Im not expecting a lot of low end torque.
In fact, Im counting on it. I like to road race and I though that if it spooled to fast, that I would just roast the tires exiting a corner at anything less than 50mph.
Although, that may still happen with this setup.
Old Feb 6, 2004 | 12:29 PM
$150FC's Avatar
Currently Winning
what do you mean by that then? if you do not want lowend torque so you don't spin your tires...
Old Feb 7, 2004 | 12:51 AM
well, if the power comes on hard and all of a sudden, vs. it spread out more over the rpms, it would be easier to mantain traction.
Old Feb 9, 2004 | 11:02 AM
Racing is Life.....
Tires and alignment vs. power sacrifice?
What tires and rear camber/toe are you running when racing? Seems a shame to have to detune the car if there's other equipment and setting you can use to help you harness the power..... I'm getting 17's shod with Proxes for the street, MT Streets on the stock wheels for drag, and maybe another set of 2 stock wheels to have 4 r-compound units for autocross or road racing.
I'm not an experienced racer yet, but learning. Just wondering what else can be done to help you whup-up on the competition!
Beast
Old Feb 9, 2004 | 03:59 PM
only a 205 right now, but im going with 225/50/r15s when the ones I have right now turn to carbon.
Old Feb 9, 2004 | 04:00 PM
anyone know of a generic equivilent to a 62-1
I am looking at a Borg Warner S200 instead of a 60-1
Old Feb 9, 2004 | 05:52 PM
Turblown's Avatar
Turn up the boost
1.15 Ptrim is too larger for stock ports...
Rotary Performance Parts
Turblown's Avatar
Turn up the boost
Old Feb 10, 2004 | 11:55 AM
http://www.hitman.hm/13BHints.htm
look at the bottom.
direct quote from hitmans website
If you really want some more power from your 13B engine , then the best way of doing it is to install a larger turbo. A good sized T04 turbo will add incredible amounts of power , and added reliability through reduced heat load. Look for a T04 with a P-Trim exhaust and 1.0 or 1.15 A/R , and a 60-1 compressor in an A/R 0.70 cover. Running the same amount of boost you should expect around 30% gains in power !
Old Feb 10, 2004 | 11:58 AM
if it turns out to be a catastrophic failure (which I doubt)
then Ill just have to port the motor, which I planned on doing eventually as a engineering project at my university.
Snook
Oct 4, 2015 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
fast13b
Mar 29, 2002 10:05 AM
