450rwhp daily driver
Old Feb 2, 2004 | 07:22 PM
is this possible? does anyone have a 450rwhp or more daily driven fd if so can you tell me more about it u can pm me or email me at BlueDragon871@hotmail.com im just intrested if u can make this much on pump gass and still be able to use the car with out a nitrous spool up or anything ? please share ur vast knowledge with me lol PEACE
Old Feb 2, 2004 | 07:32 PM
Brian7's Avatar
There are a couple people on the board that make 450whp (give or take) and daily drive their car. I'm new here so I'm not good with names..
And spool isn't a problem if you keep it in the revs!
Old Feb 2, 2004 | 09:50 PM
rixxer7fd93's Avatar
i wouldnt see the problem with it as long as your not driving the **** out of it everywhere.
Old Feb 3, 2004 | 12:22 AM
Directfreak's Avatar
I am a Jeeper Now.
That's what Boost controllers are for. you can switch between several different boost levels with the push of a button.
Old Feb 3, 2004 | 11:59 AM
yes i kno, but can anyone that is making this much power tell me a little more about their cars please, i was thinkin a hks to4r should make about 450rwhp at about 15psi with the right tunning and all associated mods, im not sure at what rpm it would spooL though, i just would like more info on setups and info about thier cars etc etc
Old Feb 3, 2004 | 01:18 PM
anyone ?
Old Feb 3, 2004 | 02:01 PM
carx7's Avatar
I have, basically, a T04R BB that I had made. I run my own custom manifold with dual W/G's, 720cc/1600cc injector setup, and all the other supporting fuel mods, haltech on a street ported, 3mm seal engine. I made 422 at 16psi and 467 @19psi on this setup. The 467 had some 101 mixed with the 91 but with further work I expect to break 500 to the wheels on 91... with my water injection setup running (it's installed just not turned on yet.
In a 4th gear pull from 1000 I see 15-16psi by 3500 and ~19psi by 3900RPM. I have full 1.2bar boost in 1st gear W/G's screaming.
Honestly, at the ~430 that I drive on teh street, it's a bit scary and intimidating and i"m still learning to drive the car.
Have any other questions?
-Chris
Old Feb 3, 2004 | 02:31 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Carx7 - What compressor wheel, turbine wheel and a/r?
STEPHEN
Old Feb 3, 2004 | 03:20 PM
ya, car with som more tunnign do you think youl be able to run 450rwhp at 15psi on pump gass ? where did you get ur car tuned, wat boost controller are you using and why did u choose haltech over apexi or aem ? any specific reason
Old Feb 3, 2004 | 03:46 PM
sub9lulu's Avatar
what kind of gas milage do you get
Old Feb 3, 2004 | 08:12 PM
any1 else runnin about 450rwhp in their daily driver ?
Old Feb 3, 2004 | 08:48 PM
$150FC's Avatar
Currently Winning
Man, chris. You just love that line, don't you?
Of course...I would, too, if i could say it.
Old Feb 3, 2004 | 08:56 PM
Roro's Avatar
It's a 66.7mm (inducer) GT series compressor with a GTQ turbine wheel in a .84A/R divided turbine housing and a 4"DP. Since I get TONS of people questioning my 4"DP it's for reduced backpressure, not top end power that I chose 4".
Old Feb 4, 2004 | 09:00 AM
carx7's Avatar
OK, this makes the 3rd time I've tried to reply... hopefully this goes through. I started above not realizing my wife was signed in
450 at 15psi will be hard pressed on a street port. I belive some have done it... with the right tunning, porting etc it can probably be done. I would think 450 At 17 is more achievable, but I won't know for sure until I try it.
Steve Kan tunned my car with a few other local Rx7 owners several months ago. If you get a group, he'll come to you.
I use the GReddy Profec B Spec II. I had the AVC-R but didnt' want/need the large size and million functions. The Spec II works great and is easily mounted.
As for the Haltech... I drive an FC so the Apexi and AEM aren't the plug n play as they would be with the FD. The Haltech was relatively cheap with good support within the community. The computer is only as good as the tunner IMO.
I must say that I'm certain there are other people making more power, less boost, better spool etc, etc. But they don't talk as much, which is fine. I am pleased with this setup especially considering the it's the first turbo system I've ever designed/put together.
-Chris
Old Feb 4, 2004 | 01:36 PM
JScott's Avatar
I'd drive mine anywhere, although it usually sit's in the garage with the weather lately. I usually take the AE on long trips around town to save gas and miles from my Avalanche. I imagine at my low boost setting of 11psi, it'd still run a low 12(maybe high 11), and be close to as reliable as a stock. I made 408rwhp with the dyno room at 104deg's at 14-15psi. Probably closer 425rwhp in more civil conditions.
Old Feb 4, 2004 | 04:00 PM
ohh, anyone else runnign high hp in their daily ?
Old Feb 4, 2004 | 04:04 PM
the car in my sig makes 360rwhp pretty nice
Old Feb 4, 2004 | 05:30 PM
Louis M's Avatar
theres more to a dd than just being able to handle it on the street... most stock rx-7s spend months in the garage fixing things, and with this massive amount of hp (well over 500hp), it'll be in there forever... people say get a dd not because you can't handle it, its because it's always in the shop
Old Feb 5, 2004 | 09:24 AM
carx7's Avatar
I think this is a function of how it's built. You can build a reliable high HP car... it just cost $$$'s and you have to do it all correctly teh first time, or yes, you will always be fixing little bugs.
Old Feb 5, 2004 | 03:29 PM
yes i agree
Old Feb 6, 2004 | 08:32 AM
fastcarfreak's Avatar
3rd motors a charm I hope
get a daily driver! much easier and cheaper.
Old Feb 7, 2004 | 12:19 PM
<- has daily driver. cheap, good on gas. cause 100 octane will rip a new hole in your pocket. to which money can never be seen again.
Old Feb 10, 2004 | 03:21 PM
nah i aint gonna be running 100octane on a dialy basis, i was just wondering if i could get this done, can anyone recomend a shop that does sick work ?
Old Feb 13, 2004 | 02:30 PM
Louis M's Avatar
Car fd this summer
well that's your first step...
Old Feb 13, 2004 | 03:38 PM
ya thats true lol
