Where can I mount the turbo?
Old Feb 2, 2004 | 12:41 AM
RotaryRyan's Avatar
DSM
Question Where can I mount the turbo?
I was wondering if you could mount a turbo on a 12a header instead of getting a special turbo header. I guess I would have to go pretty far back cause there is two pipes for a while, but I was wondering if anybody has done it or knows if it can be done. I got every thing else figured out. I can get a turbo(and intercooler if I want) for thirty bucks each at a junkyard.
Thanks, Ryan
Old Feb 2, 2004 | 12:44 AM
1984special's Avatar
So little time and money
Um, no.
For $30 you could try...
Old Feb 2, 2004 | 12:47 AM
Gregs's Avatar
here we go
Old Feb 2, 2004 | 03:47 PM
RotorMotorDriver's Avatar
Seven Is Coming
In the passenger seat seems like a cool place . I remember one car had the turbos clear at the back bumper, but it seemed kind stupid IMO.
~T.J.
Old Feb 2, 2004 | 05:11 PM
mwatson184's Avatar
holley guy
yeah a company makes rear mount turbos for f-body, and toyota tundra. Thats all i can remember. Somebody will know the website i'm sure.
-Marques
Old Feb 2, 2004 | 05:13 PM
faye x7's Avatar
brilliantly stupid
Here's a good tip guy, just do it the right way the first time. Didn't your momma teach you that?
Old Feb 2, 2004 | 08:09 PM
fatboy7's Avatar
Got Boost?
In short, NO!
In long, it would cost more in both the short and long run, if you could even get the turbo to fit down there. Rememeber that you've got to pipe the exaust from it (the exhaust leaves the turbo at a right angle to the direction it went in), then you've got the intake pipes, and the oil lines. On the oil drain you'd have to put an external oil pump to drain the now lower-than-the-oil-pan turbo.
Old Feb 2, 2004 | 08:18 PM
fatboy7's Avatar
Got Boost?
-Marques
Heck I know the guys who do it, their in my town... they mount it behind the rear axle. I'm still adamant about how stupid an idea it is regardless of the number of nut-swingers around here who think otherwise. Turbines need hot, fast-moving, pressurized air to run well. Placing the turbine where the exhaust has slowed and cooled is bad. Basically, to make it work they stick a small T4 turbine on a 5.7 liter engine. Thats a good turbine for 13B's but on a 5.7L V8?!? An all that so the can avoid using a intercooler (a reason that's a laugh and a half by itself!)
Old Feb 2, 2004 | 08:30 PM
mazdaverx713b's Avatar
Have RX-7, will restore
it would behoove you to do it the correct way by biting the bullit and spending the cash to do it right.
CaptainKRM
14
Aug 26, 2015 09:52 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
