gsl-se timing
Old Jan 30, 2004 | 01:03 PM
mazdaverx713b's Avatar
Have RX-7, will restore
Unhappy gsl-se timing
ok, my se would surge at light throttle, as if i let off and tapped the throttle again. i knew the timing was a little off, so i broke out the fsm and went at it. i did everything to spec. i lined up the leading mark on the eccentric pulley (yellow) with the pin, pulled out the distributer. i then lined up the marks on the drive gear and the dist. housing. i made sure i wasn't lining up the roll pin and the mark, i am positive it was the correct mark. once i did that i reinstalled the distributer, making sure the marks were still aligned. (i did this by looking at the 4 tooth gear and the pickup) then once i set it in, i hooked up my timing light and hooked it up to the leading wire on rotor 1. hit the light, timing was on. ok, now for the trailing timing. i hooked up the wire to the trailing wire on rotor 1 and loosened the screws on the diaphramand pushed it in until it was also correct lining the pin on the front cover up with the red line on the eccentric pulley. now it idles at 800rpm instead of 1500rpm but it has crappy throttle response and it is slow as heck. and the worst part, at light throttle, it still has the same problem. i am so lost and frustrated. 2500 dollars into this car and 4 months of work and i have about had it.
Old Jan 30, 2004 | 04:08 PM
KehoeAutomotive's Avatar
Remember that when you line the dot up on the bottom of the dist that it turns as you push it down into the front cover housing.
How does the dist look itself?
Is there any play in the shaft? Do you have to check reluctor stator gaps on these things?
Old Jan 30, 2004 | 06:17 PM
the gap is 0.35. i did not notice any shaft play. i noticed that it turned when i put it into the housing. so, i made a mental note of how it looked before i out it in and made sure it was the same when it was installed. i had to spray a little bit of pb blaster on the shaft of the diaphram to get it to move freely when i pushed or pulled on the diaphram to adjust the timing.
Old Jan 30, 2004 | 08:09 PM
Steve Shulz's Avatar
Have you been through this gammet yet? http://www.nellump.net/peri/epi/firs...gslseIdle.html
Step by step, slow and methodical. It will put you at baseline then the head scratching begins. But it does sound like a tps, have you made your test light and tested it yet? The new -se I just bought was running really bad, rich, missing, tps was way off, now its a little closer to purring and I know the plugs are bad and it needs a new cap and rotor, it makes a big difference.
Old Jan 30, 2004 | 08:13 PM
i have not made my test lights yet. i'll search on how to do that. i have the fsm as well as the haynes manual. i was suspecting a tps but wasn't too sure. i figured i would seek advice bafore i really screwed things up. i still think the timing is way off. is there anything you have to jump ,such as sticking a paper clip in a diagnostic port??
Old Jan 30, 2004 | 08:42 PM
Do a search for TPS for dummies, here it is..
https://www.rx7club.com/showthread.p...SE+engine+pics
Old Jan 30, 2004 | 08:59 PM
That's a really nice write up Steve!
I'm so glad I'm here!!
Old Jan 30, 2004 | 09:56 PM
that makes two of us!
Old Jan 30, 2004 | 11:58 PM
RacerX7fb's Avatar
paradox
On your SE... advance the Leading timing to 2.5 degrees BTDC Trailing 12.5 degrees ATDC.
This is done with the timing light attached to the T1 sparkplug wire, then turn the distributor til the pointer is exactly between the red and yellow marks. Idle RPM will increase so readjust it back to 800 RPM ... free 5% HP
Old Jan 31, 2004 | 12:53 AM
thank you for the advice! i will give it a try!!!
Old Jan 31, 2004 | 01:06 AM
i just want it to run right though. i have put this motor in it and i have been trying to make it love me, but all it does is kick me in the nuts.
Old Jan 31, 2004 | 08:19 AM
I didnt do it, I just keep it in my favorites and pass it on cause I think it rocks. Real praise goes to Zookeeper for that one.
The1Sun
Mar 18, 2018 11:08 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
tallbozo
Aug 15, 2015 02:47 PM
