air flow meter
Old Jan 28, 2004 | 03:48 AM
IveDogg's Avatar
air flow meter
i have a 85 gsl-se and was wondering if u can take the flapper door off the air flow meter and get more power, and if i can where on it do i take off the screws.
Old Jan 28, 2004 | 05:52 AM
RETed's Avatar
No.
Do you have $1,000 to purchase, install, and tune a standalone EMS?
-Ted
Old Jan 28, 2004 | 01:25 PM
j9fd3s's Avatar
Community Builder
Re: air flow meter
the flapper door make the car run
Old Jan 28, 2004 | 03:38 PM
Piranha's Avatar
what 7
Now what would make you think you could just pull the DOOR off, don't you think they put it there for a reason?
What's next, removing the wheels from the car?
Old Jan 28, 2004 | 04:12 PM
johnisenglish's Avatar
Taking out the rotors saves weight, and makes it SO much easier to cool the engine.
Old Jan 28, 2004 | 08:54 PM
RETed's Avatar
Wow, if you do that, you'd need no cooling help!
Remove the radiator and oil cooler at the same time and drain all the fluids!
That's save you some serious weight!
-Ted
Old Jan 28, 2004 | 09:09 PM
riceburner1r2001's Avatar
air flow meter
the reason i brought up the subject is cuz somebody n here was saying that u could take it out
Old Jan 28, 2004 | 11:52 PM
Evil Aviator's Avatar
Rotorhead
Re: air flow meter
You can take it out, but the car will not run unless you install a standalone EMS, as explained by RETed.
Old Jan 29, 2004 | 11:14 AM
Piranha's Avatar
what 7
Ok, in all serious, you need to research how modern (not even modern) EFI systems work. I hope the mocking above points you in that direction. http://www.howstuffworks.com .
Old Jan 30, 2004 | 03:37 AM
NoPistons4Chris's Avatar
Originally posted by RETed
No.
-Ted
Ted, sometimes if it wasn't for you, I'd get irritated from reading post like this. But seeing you reply makes it all worth it when I'm LMAO
-Chris
