I feel like and idiot!
Old Jan 28, 2004 | 03:21 AM
OK.........I REALLY hope that i didnt do something bad.......I glass beaded my spark plugs to clean off the carbon.....and i FORGOT to blow it out with air befor i installed them!! EKK im scared....please tell me that the beads just get blown out the exaust?
Old Jan 28, 2004 | 07:07 AM
timmya2's Avatar
wats glass beeding??????????????????????
Old Jan 28, 2004 | 10:17 AM
JIMMY54's Avatar
GSL-SE PRO
You might be okay BUT I'd take them out and clean them Just incase there is something still there.
Do an oil change, just as extra precaution.
I'm guessing you'll be alright since not much can get trapped in there. I do the same with my spark plugs.
Old Jan 28, 2004 | 12:27 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
At least it wasn't silicon carbide or aluminum oxide.
That'd be a REAL bummer.
Old Jan 28, 2004 | 12:56 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
I don't think I'd worry about changing the oil....
Old Jan 28, 2004 | 09:22 PM
KehoeAutomotive's Avatar
Changing the oil will not help as sand would not get into the crankcase from there.
I would be worried that the sand would get between the Apex seal the rotorhousing. I doubt that it would.....
I think you'll be ok. I would pull the plugs, blow out the holes and turn the motor over with the plugs out.
Hope everything is ok.
Old Jan 29, 2004 | 02:46 AM
jerij's Avatar
Good grief guys, I had a dirt dauber build a nest inside of the back rotor on my SE a couple of years back while it was in the ditch for 6 months getting the engine bay cleaned, etc. I slowly turned the rotor (it locked up a few times) back and forth and blew the crap out with an air hose.
Runs like a charm (but of course, not recommended if you want it to stay alive in the long run).
jerij
renjiv2
57
Jan 25, 2024 03:34 AM
Andrew7dg
Aug 6, 2017 01:41 PM
