good rim for drag on an fd
Old Jan 27, 2004 | 07:05 PM
blackkiller7's Avatar
like the title says i need something wide though
Old Jan 27, 2004 | 10:04 PM
skunks's Avatar
I'm a CF and poop smith
stock fd rims, its not about tire width but tire compound, you can easily kill your stock diff on a pair of slicks!
Old Jan 29, 2004 | 10:26 AM
well the v8 in my FD kills the stockers and i will soon have a kaaz unit so anyone else have any suggestions on drag wheels?
Old Jan 29, 2004 | 01:25 PM
i was thinking about running the spare rims up front . Any suggestions? my car might pull the front off the ground so are they safe ?
Old Jan 29, 2004 | 01:39 PM
Lots of 750rwhp+ supras run FD stockers with ET Streets, 10.xxx@135+ all day long. my .02
Old Jan 29, 2004 | 01:40 PM
you could run the spare rims, but you need to change the tires if you're faster than 55mph in the 1/4
Old Jan 29, 2004 | 01:57 PM
DamonB's Avatar
If the wheels are in the air what's it matter Using a pair of the stock spares is fine as long as you change the rubber. You don't want to go fast with what is on there now
Old Jan 29, 2004 | 04:47 PM
yeah i knew i had to change the tire but i was worried about the strenght of the rim
Old Jan 29, 2004 | 04:51 PM
i used the same set up on my 98 TT supra and didnt find it that great . I wasnt pushing 750 either . A lot of automatics have good success with that setup but mine hooked better with the ccw set up
Old Jan 29, 2004 | 11:40 PM
Use the spares up front and then powder coat them and they would look cool.
Anybody know if Racing Welds (DragLite) wheels are good for FD's??????
16x8??????
Old Jan 30, 2004 | 10:41 AM
id wonder if they (weld) make 15x10 that fit the FD
Old Jan 30, 2004 | 02:58 PM
PwRFreaK's Avatar
i wouldnt run the spares up front they are close to the same weight as the stockers, just buy a cheap set of wheels that fit up front. or you could get the weld 17"x4 front runners and they would be perfect.
Old Jan 30, 2004 | 10:32 PM
blackkiller7 I (weld) does make 15x10" wheels but they wouldn't clear the brake calipers on the FD. 16x10"????
Old Jan 31, 2004 | 10:19 AM
i really want to go with a lower rim size so i can get a wrinkle wall slick with some nice side wall like a 29 instead of a 26
Old Feb 1, 2004 | 12:38 PM
I believe RX.7com guys run 15x10" but they customize everything.
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
